Author Topic: MK3 Golf GTi 16v grey - Getting scrapped.  (Read 172562 times)
Offline dubsport
  • TDI POWAR!
Re: MK3 Golf GTi 16v grey - Shady's shady car - Tinted headlights
« Reply #570 on: 06 April 2011, 19:25 »
have you been tempted to poke a whole in it with ur finger yet?  :evil: :grin:
Offline Shady Pioneer
  • graphic designer.
« Reply #571 on: 06 April 2011, 19:58 »
Dubsport, I did get tempted but chose to choose the right path and let it rot further on it's own. Thankfully this should all be sorted by the end of the month, along with a satin paint job. Here's hoping....
« Reply #572 on: 06 April 2011, 21:23 »
:shocked:
Thats fooked, that is why I was glad to run without sill covers.
Offline Guy
« Reply #573 on: 06 April 2011, 21:36 »
:shocked:
i'm no expert... but i think that has had it  :lipsrsealed:
« Reply #574 on: 06 April 2011, 21:45 »
:shocked:
Will not be easy or cheap to repair that is for sure.
Offline Adezmk3
« Reply #575 on: 06 April 2011, 21:52 »
I had a similar problem with mine, I cut all the rot and rust out with a grinder then fabricated a sill from sheet metal and got it welded in, that was cheap enough to be honest
  • graphic designer.
« Reply #576 on: 06 April 2011, 22:01 »
:shocked:
Depends who you know Wayneyboi. :wink:
Offline Bellend
« Reply #577 on: 06 April 2011, 22:41 »
Meh, leave it for madweightsavingz.
Hows the battery situation?
Where all my moneys went.
Offline SoundillusioN
« Reply #578 on: 06 April 2011, 23:46 »
:shocked:
True that.. to be honest I have known people who get repair pieces and a garage to weld them up and as Wayne says, it can cost a bomb!.... when my others half ford got pretty bad, a man we know cuts his own stuff to fit and and can do a job like that only costing double figures!
does depend how much more there is though.
« Reply #579 on: 06 April 2011, 23:52 »
:shocked:
Respect that Kirk, however cutting and welding the flat section is not the hard part, your looking at major fabrication and welding on the lower part plus when you look at how much metal you well need to cut back to see sound metal = major work.
I only hope your not thinking of bodging it.
The other question is with the electrical problems as well is it worth repairing.  :smiley:
