Author Topic: MK3 Golf GTi 16v grey - Getting scrapped.  (Read 172430 times)
Offline ju571n
Re: MK3 Golf GTi 16v grey - Shady's shady car - Tinted headlights
« Reply #590 on: 07 April 2011, 09:59 »
I had to do the same with mine, bought it knowing i had to rebuilod the jacking point.. Started stripping the underseal away with a wire brush in my grinder onlyu to go through lots of metal with it, so i ended up doing:
Rebuilding jacking point
Replacing the entire sill
Replacing the 3/4 floor pan
I then had a piggle the other side and ended up doing:
Rebuilding  the jacking point
Replaced 1/2 the sill
Replaced the entire floorpan
Plated over to bung holes
Then one of the arch trims wasnt stuck on quiet right so pulled iut off to find that i needed to repolace an arch...
all in all with the the rear arch, two sills and some shaped floor pan tin, a litre of underseal and some seam seal i think it all cost me £100ish IIRC
My uncle started me off and showed me how to do it, i then did the rest myself so no labour costs..
Good luck on getting it fixed up Shady
Offline SoundillusioN
« Reply #591 on: 07 April 2011, 10:02 »
fook me, it amazes me how rotten mk3's can get!
no more boat jokes as clearly a MK3 wouldn't be safe at sea!
Offline dubsport
  • TDI POWAR!
« Reply #592 on: 07 April 2011, 10:06 »
 :grin: :laugh:
Offline Shady Pioneer
  • graphic designer.
« Reply #593 on: 07 April 2011, 10:20 »
Thanks for the info ju571n, that's a hell of a lot of work you did there, but in all seriousness mine it probably at a similiar level.  :grin:
Offline ju571n
« Reply #594 on: 07 April 2011, 12:34 »
Yea it sounds like a lot, but when you get down to it it doesnt seem so bad. because if your replacing the sill it you have to weld it to the lfloor pan anyway etc..
Probably took me 3-4 afternoon/nights to do it all.  Maybe did over do it a little but atleast i know itll be ok for another couple of years!  :grin:
  • graphic designer.
Re: MK3 Golf GTi 16v grey - Shady's shady car - Got rust?
« Reply #595 on: 15 April 2011, 13:27 »
New sills ordered. Hopefully will be sorted next weekend.
Offline Diamond Hell
  • Opinions я Us
« Reply #596 on: 15 April 2011, 13:54 »
Hadn't seen this for a while.
I see the usual Shady FAIL is in force.
  • graphic designer.
« Reply #597 on: 15 April 2011, 13:56 »
That is correct. I wondered how long it would take for you to bring on the Shady FAIL train.  :grin:
Offline dom
  • Back in a Mk4
« Reply #598 on: 15 April 2011, 14:11 »
Whens the deadline for getting the paint done Shady? I'm looking forward to seeing the polished rims and a matte paint job :cool:
  • graphic designer.
« Reply #599 on: 15 April 2011, 14:17 »
Volksfest is my deadline. As soon as I have the sills sorted I'm going to get my bootlid replaced (replacement I have but need the window transferred to the new one). Once that's done I'll be sanding it down and cracking on. The end of April may even see the prep beginning.
