Author Topic: Nitrous injection installed-Dyno result out! 04/08/2010.  (Read 19626 times)
Offline Harris GT TDi
Re: Nitrous injection installed-1/4 mile time up 27/07/2010.
« Reply #60 on: 30 July 2010, 17:55 »
Awesome mate!
Golf GT Tdi!
New Style 18" RS4 Alloys, Eibach -30mm Pro Kit Lowering Springs, New Style Black GT Lights with H7 Anti Glare Xenon's, Colour Coded Lower Rear Bumper, Full LED Bulb Conversion Throughout,
To come, re -map!!!! :)
Offline Hurdy
Re: Nitrous injection installed-Dyno result out! 04/08/2010.
« Reply #61 on: 04 August 2010, 19:26 »
Update...
Went to have a dyno run with the nitrous today. The guys were very helpful and one of the operators has nitrous for his car, so I was in safe hands. It was a Dyno Dynamics "pessimistic" set of rollers at RS Tuning in Leeds. I chose their dyno specifically as they are just about the lowest (as most consider) that are near enough to me who I trust to dyno it correctly.
So, below is a pic of how they had to strap it down. They said strapping down this way loses 2-3% as it pulls the wheels so hard down into the rollers  :undecided:
Here's the bit you've all been waiting for...
438.7hp and a peak torque of 510 lbft on nitrous
339.8hp and peak torque of 381lbft without nitrous.
The settings are less agressive for the dyno than on the road as the nitrous wasn't even set to start until 3200rpm.
Absolutely no sign of slip on the DSG box and AFR's on nitrous were a solid, held 11.5.
Interesting for me is that my torque on nitrous is as high at 6000rpm as the peak without nitrous. Also I'm making more power at 3500rpm on nitrous than my peak power without.  :evil:
This is a REALLY impressive modification and it would be interesting to compare it to say, the GT2871R that I was thinking of fitting.
Seat Leon Cupra Black 290 DSG
Offline jeynesey
  • Non VW but still VAG
« Reply #62 on: 04 August 2010, 19:31 »
Awesome  :cool:
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
« Reply #63 on: 05 August 2010, 08:42 »
How long do those 2 bottle last Hurdy? And how much to fill them up?
Offline Hurdy
« Reply #64 on: 05 August 2010, 13:26 »
£40-50 a bottle (11lb) depending on where you go.
I'm using the nitrous quite a bit more than I normally would at the moment for settings etc and they lasted me 1.5 months. Normally, once I've finished the settings I reckon they will last around 2 months on the 100bhp nozzles. You can double that time for 50bhp nozzles and again for 25bhp nozzles. It is probably more accurate to say how many runs and that would be around 40 quarter mile runs on the 100bhp nozzles, 80 on 50bhp and 160 on 25bhp. Based on using around 10 seconds of nitrous a run :cool:
Offline Saint Steve
« Reply #65 on: 07 August 2010, 21:53 »
Sorry to hear john about the Engine going wrong mate.  :sick:
Hope she's back to full health soon mate.
Offline bacillus
« Reply #66 on: 07 August 2010, 23:25 »
What's happened??
Without traction power is nothing!
Offline Hurdy
« Reply #67 on: 07 August 2010, 23:46 »
Normal service will be resumed as soon as possible :cry:
Offline Ed30DSG
« Reply #68 on: 08 August 2010, 10:27 »
Oh dear! Good luck with the rebuild ... 2.2l conversion? lol
What failed?
Offline Hurdy
« Reply #69 on: 08 August 2010, 11:30 »
Head gasket leaking - needs a steel gasket
Exhaust has a cracked flange weld at the turbo end (probably due to heat/extra gases) - needs a re-weld
Clutch is slipping (only on nitrous) - upgraded clutchpack needed unless I take the nitrous off in which case it is okay.
Fuel pump cannot cope with nitrous AND engine demand - upgrade fuel pump unless I take the nitrous off in which case it is okay.
440bhp and 510lbft was always going to stretch the car. :shocked:
