Author Topic: help !! does anyone no about thease?  (Read 1798 times)
Offline darren1.8t
  • I HATE FRENCH CARS
« on: 05 July 2010, 20:02 »
hi guys i have trouble getting 1st and 2nd gear is there anyway i can re aline the linkage ?? its not like the other gear box were you can use  two pins to set the gears? can anyone help
Offline darren1.8t
Re: help !! does anyone no about thease?
« Reply #1 on: 06 July 2010, 07:40 »
someone must no about thease gear boxes?
Offline chrisj
« Reply #2 on: 06 July 2010, 08:38 »
I don't know if this is helpful or not but i only had 3rd and 4th the other day. put a new part on and it's fine now and i've got all gears. couldn't tell you the name, but could get the part number. was £11 odd in vw.
R Tech stage 1 AUM, Pipercross panel filter, forge 007p, Santa Monica's,Lowered 35mm Jamex Shocks and springs, Milltek Exhaust, mk5 rear wiper
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #3 on: 06 July 2010, 08:44 »
Sounds like you may have worn gear linkage
Offline darren1.8t
« Reply #4 on: 06 July 2010, 14:23 »
hi chris what part was it? how much is the gear linkage?  :wink:
Offline chrisj
« Reply #5 on: 06 July 2010, 16:33 »
I'm not sure. It's the part that's attached to the end of the two cables you can see in your picture. can give you the part number when i get home if that's any good. It did cure my problem of the lost gears though. The part i bought was under £12 with vat
Offline darren1.8t
« Reply #6 on: 07 July 2010, 07:51 »
yeah ok m8 cheers but have you got the same gearbox?  :wink:
Offline chrisj
« Reply #7 on: 07 July 2010, 09:00 »
mines a 99 agu if that helps
Offline darren1.8t
« Reply #8 on: 07 July 2010, 15:51 »
yeah mine the same mate  :wink:
Offline darren1.8t
« Reply #9 on: 08 July 2010, 06:30 »
so does anyone have a guide on this? cheers
