Author Topic: water scale marks on black car  (Read 4621 times)
Offline javalin
« on: 05 July 2010, 10:40 »
Hiya
Everytime I wash the g/f's car it ends up with what looks like lime-scale is left on it.  Its been clay'd, polished and waxed earlier in the year so the surface is nice.  I use a wash mit and the TBM.  I use a micro-fiber chammis to dry it after.
Also - its seems to get a light haze on the bodywork very easily - its not clean black not a high-gloss black look.  Is this possibly where I haven't got the wax/polish off enough - maybe it dried in the sun a bit?
What am I doing wrong?  Is it as simple as needing drying towels?
Cheers,
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Guy
Re: water scale marks on black car
« Reply #1 on: 05 July 2010, 11:40 »
i think some pics of the offending haze would be good
have you thought of just running around the car with some QD and a microfibre after you wash it?
Offline javalin
« Reply #2 on: 05 July 2010, 11:58 »
thanks guy - will try to get one tonight.
Cheers,
James
Offline Dawnskaybug
  • GoAPR.co.uk
« Reply #3 on: 06 July 2010, 00:19 »
I had the same problem and went to distilled water in my wash bucket it helped alot.
APR K04//APR Carbonio Intake//Hawk HPS pads//Adams Rotors//Billy Banks Downpipe//APR Rear Sway bar
Offline javalin
« Reply #4 on: 07 July 2010, 07:15 »
Hiya
Picture as promised.  Had to wait for g/f to get home from work before dark!
You can see the watermarks in amoungst the dirt I hope
James
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #5 on: 07 July 2010, 16:08 »
have you been washing the car when its been in direct sunlight and on a very hot day?
This can be down to the rinse water drying to quickly, however you made find giving it a good wax afterwards gets rid of the water marks, or like Guy mentioned use a quick detailer and microfibre
Offline javalin
« Reply #6 on: 07 July 2010, 16:22 »
yeah its really bad if you let it dry when hot.  Consequence of having a black car in the summer I guess.
The last time (photo'd) I was washing it at 6am (don't ask) and car was cold.  It was fine till I sprayed water over the windscreen to test some glass sealant, then look what happened!  Car was actually cold at the time.
Any ideas?  Have we just got scaley water?
James
Offline Guy
« Reply #7 on: 07 July 2010, 21:48 »
can see the water marks... can't see the paint  :laugh:
here is my suggestions if you can't get yourself an in-line water filter to combat hard water
1. make sure you use a clean wash mitt with the 2 bucket method
2. try washing a panel at a time working from the roof down, dry the panel just after you wash it.. it IS possible to wash panels without getting other panels wet
3. use a drying towel followed up with a microfibre
4. clay, polish and then a few coats of wax will get rid of the marks and lessen the amount of water that sits on the paintwork and increase run off
Offline javalin
« Reply #8 on: 08 July 2010, 06:48 »
ok - thanks guy.
Offline Dawnskaybug
  • GoAPR.co.uk
« Reply #9 on: 08 July 2010, 12:35 »
vinegar sometimes helps. try a 50 50 mix.
