Author Topic: water scale marks on black car  (Read 4596 times)
Offline dubber36
Re: water scale marks on black car
« Reply #10 on: 08 July 2010, 18:01 »
Try sheeting the water off when you rinse with an open hose rather than spraying it. With a well waxed car, this will almost self dry it. Then dry the rest with a mf cloth using a QD spray or AG Aqua Wax as an aid.
Offline asif
« Reply #11 on: 08 July 2010, 20:23 »
Vinegar???
MK7 GT Bluemotion Tech TDi 150
Offline Guy
« Reply #12 on: 08 July 2010, 23:02 »
vinegar sometimes helps. try a 50 50 mix.
mmmmmm.... acidic
Offline javalin
« Reply #13 on: 09 July 2010, 09:23 »
Thanks Dubber,
I think I'll use some of the megs no80 (or is it 82..?) 3/10 cut polish and then, jetseal and put a few coats of wax on it.  Hopefully that will clear the dullness (oxidation?) of the paint too!  :smiley:
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline asif
« Reply #14 on: 10 July 2010, 21:25 »
Jeez detailing is crazy there are so many options and ways to egt a pukka finish. This jetseal gets a regular mention though so may need to invest in some of that :)
Where is a cheapest for that stuff?
Offline asif
« Reply #15 on: 10 July 2010, 21:26 »
If you've got a black car then I heard that Poorboys black hole is supposed to be really good and hides loads of marks.
Offline waxamomo
« Reply #16 on: 13 July 2010, 17:47 »
Have a look here:
http://www.waxamomo.co.uk/productcart/pc/viewPrd.asp?idproduct=78&idcategory=8
Chris
Offline javalin
« Reply #17 on: 13 July 2010, 17:48 »
yay - Waxamomo stocks Jetseal! :-)  Top product.
James
