Author Topic: gearknob change  (Read 1526 times)
Offline Horney
gearknob change
« on: 04 July 2010, 18:07 »
I think my Polo has the same setup for it's knob as the MKIV. It seems to have a one use type clip on the bottom.
How do you guys fit different knobs? I've got a drilled 8 ball that used to be on my camper and fancied it on the polo but looking at it I'm not sure it's possible.
nick
Offline golf-sib
  • Турботазик
Re: gearknob change
« Reply #1 on: 04 July 2010, 18:15 »
nick
What polo you got, I had a 6n with them clips I think your on about, my other knob didnt fit as it didn't have a clip, just explandable plastic hole, just whacked it on and tightened it up with some cable ties, did the trick.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Horney
Re: gearknob change
« Reply #2 on: 04 July 2010, 18:18 »
It's 6N2 TDI so has a MKIV gearbox and shift linkage. I've had a look and the system looks exactly the same as the MKIV.
The problem is the knob I want to fit is just a proper pool ball that's been drilled. I'm not sure if I can therefore get it onto the shaft or if with the original knob removed the shaft will be short underneath so with just the pool ball on it's be too low down.
Nick
Offline T_J_G
Re: gearknob change
« Reply #3 on: 04 July 2010, 18:29 »
Any help Nick?
Offline Horney
Re: gearknob change
« Reply #4 on: 04 July 2010, 18:31 »
Yeah, how much shorter is it without the knob on? Does the shaft go all the way up inside the knob?
God this sounds gay :grin:
nick
Offline T_J_G
Re: gearknob change
« Reply #5 on: 04 July 2010, 20:15 »
It goes to the bottom of that grove you can see at the top.
Offline richw911
