Author Topic: optimax  (Read 13882 times)
starry
optimax
« on: 07 June 2003, 13:08 »
is optimax realy any good ,ive just filled up with the stuff and will have to see what happens. does any one else use it if so do you think its any good.
;Dcheers Starry ;D
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
lee
Re: optimax
« Reply #1 on: 07 June 2003, 14:58 »
Hello
When I first got my 16v mk2 I was running it on 97 super unleaded then I started using 98/99 optimax The car does seem to run better.
Lee
jelly
Re: optimax
« Reply #2 on: 08 June 2003, 01:32 »
I got quite a noticable boost in perfomance when I put Optimax in my GTI. That was changing from BP 97 Fuel. Some of my friends haven't noticed such changes but I have, so i stick with it.
Hope you get some better performance
Jelly
Offline richandhazel
Re: optimax
« Reply #3 on: 08 June 2003, 11:31 »
I've just filled the Audi up with optimax ready for Santa Pod. When I put the Audi on the rolling road, it was the difference between being under 200BHP or over 200BHP............Its great stuff ;D
Offline kevin
Re: optimax
« Reply #4 on: 12 June 2003, 07:15 »
if your engine is set up on the stuff you will notice the difference,95ron to i think 98+ is quite a lot but you will need a RR tune up or get your timming advanced to get full benifit
regards kevin
lee
Re: optimax
« Reply #5 on: 13 June 2003, 01:31 »
Hello
Dont know if this will help but on the inside of my 16v mk2s fuel cap, it recommends 98 ron minimum
Lee
Offline modulater
Re:optimax
« Reply #6 on: 21 June 2003, 00:06 »
I use optimax in my 16V and the thing goes like a rocket, In the owners handbook it says 98 RON should be used for prolonged high speed driving, well I guess thats a little run to the shops for most of us.
Offline VWaxilMK1cab
  • 1992 mk1 cabrio gti
Re:optimax
« Reply #7 on: 24 June 2003, 18:49 »
It says in most cars handbooks that they should be run on 98 ron, and have to be adjusted to run on any less, but most right hand drive cars have this setup when leaving the factory so run on 95ron ok.
Like Kevin says, if you intend to run a higher octane, its advisable to get the timing advanced to suit.
I'm not sure if using a higher octane would actually ive any benefits looking at the facts, but I hope someone can tell me otherwise!
Offline madmuppets
Re:optimax
« Reply #8 on: 25 June 2003, 10:02 »
I must admit since we have used Optimax we get more miles to the Gallon. Around 350 miles to a full tank of fuel as apposed to around 310 before.
Offline firefighter
Re:optimax
« Reply #9 on: 26 June 2003, 08:48 »
I often run my mk2 8v on optimax to travel from Durham to East Sussex & it pulls like a train on it & at 90 it returns 36.8 to the gallon on 340 mile run. 1st time I put optimax in it seemed no different about town but on a run the engine is much torqier & runs a lot better.
