Author Topic: optimax  (Read 13880 times)
Offline mk1
Re:optimax
« Reply #20 on: 15 July 2003, 21:59 »
I have just turbod my 83 gti and on unleaded it needs more retarding on the ign timing when boosting than on optimax. No rolling road test to prove hp gains but I would think more timing advance = more HP (up to a limit). Hard to say if the engine makes more power on optimax over unleaded, pulls like a train on both ;D. Just my 2p worth, Steve.
Offline Flip
Re:optimax
« Reply #21 on: 15 July 2003, 23:13 »
I have just discovered that Optimax tastes EXACTLY the same as regular unleaded!! If youre gonna sifon a tank use a clear hose!!
Offline richandhazel
Re:optimax
« Reply #22 on: 16 July 2003, 01:39 »
LOL  ;D ;D ;D
Offline edjay
Re:optimax
« Reply #23 on: 24 July 2003, 17:56 »
I've used Optimax for about 3 months & it makes a
big difference to my 8v, For some reason when I run it on standard unleaded it uses oil, with the optmax it does'nt. I also get more miles for my money thus making it cheaper............The bigger the RON the bigger the BANG !!!
Offline sijunior
  • GTI 20V Turbo
Re:optimax
« Reply #24 on: 28 July 2003, 22:13 »
I have to agree,
I went down to Cornwall in my 1.8T with a tank full of super unleaded and got just over 300 miles to the tank,
On the way back I filled up with Optimax and got just under 350 miles to the tank.
SWEET ;D
i-espedair
Re:optimax
« Reply #25 on: 02 August 2003, 14:49 »
I have used optimax in every performance engine i have owned after reading the independant test report when it was launched.
If you speak to anyone in VAG who knows about fuel they will recommend it! Porche even print it in their UK handbooks!!!
I bought a Mk3 2.0 8v which was running on regular and after about 5 tanks the difference was very noticeable. I would point out it wasn't instant. But after a good month of using it there is an increase in performance and the whole engine runs smoother!
One of the biggest affects, which only one of you has noticed, is your engine burns a lot less oil, mine burns almost none atall. This is because the additives in the fuel reduce engine wear and keep things nice and clean.
It is slightly more money but if you do the math on the improved mpg it definately breaks even, if not works out cheaper than regular unleaded. Also less engine wear = less oil and reduced servicing bills, greater engine life.
I do not work for Shell. But have had a great deal of experience when it comes to fuels! This is by far the best available and the only draw back is you need to live near a Shell garage. It would be nice if other fuel suppliers produced a performance fuel and we could follow the Germans upto 100 ron!
Definately no placebo here! If you don't notice the difference then your engine is in a worse state than you realise!
Offline AdamB
  • The Perfect Storm
Re:optimax
« Reply #26 on: 03 August 2003, 17:37 »
My engine seems to run hotter according to the temp gauge, since I started using it - coincidence? It doesn't overheat though, so I will carry on with it
I don't own this anymore - I just can't be arsed to change the picture
