Author Topic: My Golf's Hesitating when under boost???  (Read 9076 times)
Offline johnford60
  • MK7 GTD 3 Door
Re: My Golf's Hesitating when under boost???
« Reply #10 on: 06 July 2010, 15:14 »
Took for drive earlier.
Pulled out and when changing from 1st to 2nd gear it bogs down, almost like engine cuts. Wouldn't be anything wrong with the DSG box i hope!. When up and running its underpowered and hesitates more and more now.
It bogged down 3 times within 5 minutes, but only when pulling away from 1st to 2nd gear. it almost feels like traction control taking the power off at first but its not that.
When it get's warmer it doesn't seem to do that!
John
Offline johnford60
  • MK7 GTD 3 Door
« Reply #11 on: 06 July 2010, 19:35 »
Faults Found:
000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
               P0234 - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 20
                    Mileage: 145435 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:49:20
             Freeze Frame:
                    RPM: 6653 /min
                    Load: 81.5 %
                    Speed: 130.0 km/h
                    Temperature: 87.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
012403 - Fuel Pump Circuit: Electrical Malfunction
               P3073 - 004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 147682 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:09:09
             Freeze Frame:
                    RPM: 903 /min
                    Load: 25.5 %
                    Speed: 6.0 km/h
                    Temperature: 47.0°C
                    Temperature: 37.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.097 V
Hope someone can help me out?
John
John
Offline winrya
« Reply #12 on: 13 July 2010, 17:20 »
As you had similar issues to me,
I have just replaced the 4 coil packs and fingers crossed the car is fixed.  Just had a 15 minute drive and couldn't replicate any hesitancy at any point in the rev range and it now pulls much more freely to the red line.  Also idles much more smoothly.  The last time i took it out and gave it a thrash i was almost head butting the dash!
I'm very pleased and saved a nice amount by ordering from ECS Tuning (USA).  Cost £77 for 4 delivered and took only 4 working days to arrive  :cool:  Cheapest price I could get from dealers was £33 x 4 = £132
Time to get back to enjoying the car :smiley:
Offline johnford60
  • MK7 GTD 3 Door
« Reply #13 on: 19 July 2010, 22:32 »
Just done live date log:
I got lots of Misfires on cylinder 2 :undecided:
Intake Air Mass peaked at 179.14g/s at 5600 rpm !! ( I'm sure these needs to be at least 190g/s) It never went any high than than this, just  up into the 170g/s.
I think i'll change MAF Sensor tomorrow and maybe 1x coil pack  :rolleyes:
John
Offline Holepunch
« Reply #14 on: 22 July 2010, 14:23 »
Just picked mine up from the garage who advised that the misfire hadn’t created an error.  I'm pretty sure they only ran the scan when the car was stationary, so can you advise how a live scan is carried out?
I also had a rev D DV fitted at the same time which has improved responsiveness but not made any change to the misfire problem.
Offline johnford60
  • MK7 GTD 3 Door
« Reply #15 on: 22 July 2010, 15:13 »
Hi,
Have you got Vag Com?
John
John
Offline Holepunch
« Reply #16 on: 29 July 2010, 16:42 »
I havent but the print out provided by the garage only lists faults with my RCD 510 DAB (which I retro fitted) and nothing else.
Offline johnford60
  • MK7 GTD 3 Door
« Reply #17 on: 31 July 2010, 12:23 »
Mine's got no faults on missifre, but when i look at the live data of engine running ,block 14/15 then it missifre's quire a bit on different cylinders!
John
Offline Holepunch
« Reply #18 on: 11 August 2010, 20:55 »
Just got my car back after getting 4 new coil packs + plugs and fitted its totally transformed the car.  The hesitation when under 3/4 to full throttle has completely gone + it idles and starts better. The engine feels much more responsive and pulls harder although the previous week I had the latest revision DV value so I think it could be a combination of the two.
As I have only had it back a day I won’t give it a full clean bill of health yet, but it sure feels that way
Offline johnford60
  • MK7 GTD 3 Door
« Reply #19 on: 12 August 2010, 21:59 »
I've fitted a new fuel pump to mine and it's sorted. See my other post on here.
John
