The garage
Radiator Fan
Topic: Radiator Fan (Read 5646 times)
benjam_in
Here all the time
Radiator Fan
11 August 2003, 11:18 »
Just changed my cooling fan on the radiator so now i can sit in traffic!!!! The fan i took off had three connectors on it and the new one only had two! Just wondering if any one knows what the difference is??
Golf Mk2 Gti 1988
richandhazel
Global Moderator
Forum addict
Re:Radiator Fan
11 August 2003, 11:26 »
I think the 3 connector one has a 'run-on' facility. Something to do with the fan coming on when you have shut down.
I went the other way and fitted a 3 connector one in place of my 2 connector one. Had to swap over a bit of loom out of the my Mk2 so that I had the right connector.
benjam_in
Here all the time
Re:Radiator Fan
11 August 2003, 11:33 »
My two connector one has a run on! could be that i just got lucky in connecting the right wire on!
think both of the wires did have power after the ingnition was off!
but it was a hot day so cant be sure!
Last Edit: 11 August 2003, 11:34 by benjam_in
Golf Mk2 Gti 1988
richandhazel
Global Moderator
Forum addict
Re:Radiator Fan
11 August 2003, 11:45 »
I found some info in the Mk2 Haynes manual..............I'll scan it and post it for you, but basically the 3 pin one is twin speed, the 2 pin one is single speed.
benjam_in
Here all the time
Re:Radiator Fan
11 August 2003, 11:51 »
Cool! that was one of me thoughts yesterday! hunted throught the wiring diagrams at the back of my haynes but there were so many for Radiator Fans i just worked it out for my self!
Golf Mk2 Gti 1988
richandhazel
Global Moderator
Forum addict
Re:Radiator Fan
11 August 2003, 11:55 »
Here's what I found:-
benjam_in
Here all the time
Re:Radiator Fan
Reply #6 on:
11 August 2003, 12:01 »
Should really read that section shouldnt i! oh well! yea i did replace a 6 blade with a 4 blade! but it was free! if its useless ill have to do an upgrade!!
Last Edit: 11 August 2003, 12:01 by benjam_in
Golf Mk2 Gti 1988
modulater
Re:Radiator Fan
Reply #7 on:
15 August 2003, 04:16 »
As rich and hazel said the thermoswitch has three pins for twin speeds. I remember reading something by Steve Cresswell that the 3 pin thermoswitches aren't available anymore and VW give you a 2 pin one these days. I remember the article because the bloke in it cut the original connector off and put spade terminals on and then obviously not having a clue he put them on so that the fan span the opposite way blowing the air out the front of the car.
He wondered why he overheated.
benjam_in
Here all the time
Re:Radiator Fan
Reply #8 on:
15 August 2003, 12:17 »
Yea i saw that one too!! in the golf last month! It did make me think twice when doing mine!!
Golf Mk2 Gti 1988
jerry
Just got here
Re:Radiator Fan
Reply #9 on:
15 August 2003, 13:30 »
the radiator fan on my 89 mk2 golf gti is not working, car over heats in traffic and the fan doesnt come on. do i have to replace the whole radiator or is it just bits i need to replace, also is it an easy job to do and at what sort of cost.
cheers
The garage
Radiator Fan
