Author Topic: Oil Cooler  (Read 5069 times)
Offline SoundillusioN
Re: Oil Cooler
« Reply #10 on: 21 June 2010, 16:00 »
cam cover will get bloody hot when its up to temp, oil temp will usually sit around 90degrees which is around the boiling point of water after all ;)
if gauge is sat at max that means your wire is earthed somewhere or the sensor is duff. the temp sensor wire is red/yellow
hmmm so maybe still not enough to trigger oil cooler then?.... yeah you helped me out loads while i was having my fun with wiring! I ended up moving on for a bit as i was having nightmares and suspected some of the senders to be duff. on this note though, whats the sender in the exspantion tank doing?
Offline Horney
Re: Oil Cooler
« Reply #11 on: 21 June 2010, 16:02 »
Low level indicator.
nick
Re: Oil Cooler
« Reply #12 on: 21 June 2010, 16:10 »
nick
doh!.. oh yeah!.... sorry, five years plus out of it has made me a bit of an amatuer.  :embarassed:
