Author Topic: Oil Cooler  (Read 5083 times)
Offline SoundillusioN
Oil Cooler
« on: 21 June 2010, 00:29 »
Flushed out and replaced oil, changed filter etc.  Engine has been getting too hot, found the thermostat to be the culprit but also i have now noticed the oil cooler doesnt seem to be doing anything!... the engine was stood for some so this is the first time i've noticed.  am i right in thinking there is a thermostat for this too when the oil reaches a certain temp?  cooler and hoses are always stone cold.  any ideas?
Offline Lee_dub
Re: Oil Cooler
« Reply #1 on: 21 June 2010, 09:25 »
Is it an aftermarket jobbie?
Black mk1 2.0 16V - woop
Re: Oil Cooler
« Reply #2 on: 21 June 2010, 13:00 »
no standard GTI jobbie.
Offline Lee_dub
Re: Oil Cooler
« Reply #3 on: 21 June 2010, 13:05 »
Then no I don't think there is a stat mate.  theres deffo not one on KR engines (I know mk2 but ive never owned a mk1 engined mk1  :grin:)
Offline Horney
Re: Oil Cooler
« Reply #4 on: 21 June 2010, 13:06 »
Thermostat in the oil filter housing is rated 110 deg. Either you ain't hitting that temp or it's stuck closed which is quite common. Pop over to the MKI site as theirs some good threads on there about refurbing the thermostat as new ones are no longer available.
The reason I know all this? I have one fitted to my MKII. :cool:
Nick
Re: Oil Cooler
« Reply #5 on: 21 June 2010, 13:21 »
Nick
thought as much and yes its defo hitting temp to open if it wanted to... hmmmm, can it be run without the stat, i know it would take longer to warm up... ive already taken the water stat out for now which has helped loads!
Offline Horney
Re: Oil Cooler
« Reply #6 on: 21 June 2010, 13:27 »
Yeah you could run it without but you'll have to be really careful on warm up. If it's getting that hot though it should stink and the engine bay be cooking. You sure your temp gauge is working OK?
nick
Re: Oil Cooler
« Reply #7 on: 21 June 2010, 13:47 »
not a good idea to have it without a stat, particularly in the cold weather. engine will take an age to get up to temp, moire engine wear and more fuel etc. if cooling system appears fine without it then stat was dead or the waterpump is weak, or perhaps as said gauge over-reading. do you have oil temp display and if so what was it saying?  what temp did the dash gauge show?
Re: Oil Cooler
« Reply #8 on: 21 June 2010, 13:50 »
nick
yeah i know its probably not worth going down that route as its not really that necessary unless bewing driven super hard, just not happy when something isnt working.  believe it not, after my complete rewire the only things i cant get to work is the MFA and the temp gauge (reads max all the time) so am just guessing that its too hot.  it gets up to temp really quick, even the cam cover is really hot!... just assumed that the oil cooler should be kicking by then!?  i also know its not running right, needs tuning, fuelling is all wrong which wont help matters...
Re: Oil Cooler
« Reply #9 on: 21 June 2010, 15:24 »
cam cover will get bloody hot when its up to temp, oil temp will usually sit around 90degrees which is around the boiling point of water after all ;)
if gauge is sat at max that means your wire is earthed somewhere or the sensor is duff. the temp sensor wire is red/yellow
