Author Topic: EGR removal **Now with pics** :)  (Read 5469 times)
Offline mowlamb
  • MK4 GT TDI 130 - DERV POWER!!
« on: 20 June 2010, 15:38 »
I'm in the process of removing my egr and putting in the delete kit. The only problem at the moment is that I can't get to the 2 bolts holding it to the manifold. How is the best way to get to these? Also can I drive my car with my egr like this as I might need to get it somewhere to get to these bolts?
« Last Edit: 20 June 2010, 19:49 by mowlamb »
Offline EuanGtTdi
Re: EGR removal
« Reply #1 on: 20 June 2010, 16:04 »
un-clip/un-bolt everything of the old egr, remove this from the inlet manifold and leave the flexi-metal pipe from the turbo/manifold! then get a small spanner on the two bolts that come from the turbo/manifold best trying from the air box side removing the plastic tubing that goes to your turbo intake pipe, once get that metal flexi pipe off put the wee gasket and cover plate on! also wd-40 them before you do it and i got more purchase from that side off the bay mate! they are quite stiff so do try hard mate.
Euan
« Last Edit: 20 June 2010, 16:07 by EuanGtTdi »
Offline mowlamb
Re: EGR removal
« Reply #2 on: 20 June 2010, 16:10 »
Does the EGR just pull out of the flexi metal pipe? I tried pulling it but it didn't seem to budge.
Offline EuanGtTdi
Re: EGR removal
« Reply #3 on: 20 June 2010, 16:12 »
sure it got 2 allen key headed bolts go into the underneith like the 3 that hold the egr to the inlet manifold mate!
Euan
Offline mowlamb
Re: EGR removal
« Reply #4 on: 20 June 2010, 17:18 »
All done now mate your are a star :afro:
Offline EuanGtTdi
Re: EGR removal
« Reply #5 on: 20 June 2010, 17:24 »
gdgdg mate you member and put the o-seal in yeah? dont worry about that noise it makes when you turn the car off as it makes that now youve removed the shudder valve
Euan
Offline mowlamb
Re: EGR removal
« Reply #6 on: 20 June 2010, 17:28 »
the o seal between the allard pipe and manifold yeah?
Offline EuanGtTdi
Re: EGR removal
« Reply #7 on: 20 June 2010, 17:29 »
yeah goes in the bit that a circle shape with a flat at the top
Offline mowlamb
Re: EGR removal
« Reply #8 on: 20 June 2010, 17:34 »
yeah remembered that thank god lol. Gunna go for spin in a bit so hopefully I've done it all properly :)
Offline Rhyso
Re: EGR removal
« Reply #9 on: 20 June 2010, 17:35 »
KAAAAAABOOOOOOOOOOOOOOOOOOOOOOOOOOM
 :laugh: :laugh: :laugh: :laugh:
 :laugh: :laugh: :laugh: :laugh: :laugh:
