Golf mk5
Creaking
Topic: Creaking (Read 1556 times)
Enforcer
Creaking
18 June 2010, 17:29 »
Hello chaps,
One last question: I find the front of the car creaks a bit when going over speed bumps.
Is this a common issue?
Thanks
ub7rm
Re: Creaking
18 June 2010, 19:39 »
I have this on mine, seems to be worse when cold
It has always done this but got worse (then subsequently better when I had one of the tie rods replaced. Still a little bit of creaking though.
2020 BMW 128ti
2017 Golf GTD Estate
Enforcer
Re: Creaking
18 June 2010, 22:04 »
Thanks chap - as I've just purchased the car (from a small garage) I was wondering whether to take it back and ask for the "fault" to be rectified? But sounds like it's a strange "VW" issue...
Hurdy
Serious forum addict
Re: Creaking
19 June 2010, 00:09 »
Sounds like the front ARB is dry. A little grease around there on both mounts should help reduce the creaking noise.
Seat Leon Cupra Black
290
DSG
Colinv
Qualified VW mechanic
Re: Creaking
19 June 2010, 09:03 »
Like hurdy says, try to grease in and around the arb bushes, failing that it may possibly be the top strut mounts that need greased up
Enforcer
Re: Creaking
19 June 2010, 15:18 »
Thanks guys - do you know of any DIY guides to help me locate what I need to grease?
Golf mk5
Creaking
