Author Topic: are all mk4 drive shafts cv joint the same ? help please  (Read 12728 times)
Offline linz
  • vee-dub
ok well my drive shaft cv joint is being a pain in the arese an seems we cant find a solution :(
are all driveshafts in the mk4 1.8t the same?
we tried the diesel one that was too short the standard 1.8t one is too long
its keeps muckng up the cv joint
so what can i so to rectify the problem please help i would actuallylike my car back this century  :cry:
Offline DarkGti
the 1.8t driveshaft is too long for a 1.8t? i dont understand
Offline haf1zur
second place i posted regarding this
Offline old_n07
If you lower the car you are altering the geometry of the drive shaft in relation to the hub which in effect lengthens it slightly in relation to it's position rather than the physical size of the shaft  :huh:
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline linz
  • vee-dub
im thinking im just gonna have to bite some of my pride an raise her up a bit  :sad:
Offline DarkGti
so in theroy if you want to stop breaking drive shafts you just need to raise it up??
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
no brainer then
Offline Hulmie
  • White MK4 1.8T AGU K03s
its either raise suspension or raise the engine to take the stress off the cv joint
Offline Purely VAG
By CV joint im guessing you mean Outer CV joint as theres an Inner. And size as in width/essential length are all the same but dependent on what engine model the diameter of the CV is different - I.e wrong one wouldn't even fit onto the driveshaft splines.
Can i ask what CV's your using ? The 5 speed shaft spliners are smaller than 6 speed, when i had 5 speed i shattered them all the time but they were from motor factors.  You using Genuine ones?
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline linz
  • vee-dub
no jordy its the inner cv joint the keeps goin
and just ordered me a genuuine one :)
