Author Topic: still got boost problems!  (Read 2655 times)
Offline barry-gti
« on: 15 June 2010, 09:20 »
So... i've still got boost problems!
The VVT has been changed and has sorted the timing problem, a resistor is in place where the secondary air intake was, and 3-4 different N75's have been tried!
The fault is most definatly electrical as whenever the Maximum charge pressure surpasses fault is cleared it boosts fine through 1st - 2nd gear and once it senses a bit too much boost it all goes t!ts up!
Basically now, it boosts weak to 15psi and as soon as it touches it, it rapidly drops to about 5-8psi. and stayes there the whole rev range... if you take your foot off and plant it back down it does the same thing again and again... untill you clear the fault... then it's 20odd psi for a bit, and then the same symptoms...
it sounds like a boost leak when it goes into this limp mode... but it's definatly not
We're looking to change the MAP sensor when i can find one attached to a standard side mount
But, does anyone else have any ideas what it could be?
Offline topher
  • Administrator
  • fully functioning
Re: still got boost problems!
« Reply #1 on: 15 June 2010, 09:41 »
if it's not a sensor (try maf as well as map) only thing i can think of is the actuator or it's rod got bent/damaged during the engine swap.. although i'm sure i had a quick check for that last time you were over this way :undecided:
what are they getting from logs of the map and maf sensors?
Offline barry-gti
« Reply #2 on: 15 June 2010, 10:37 »
We're not getting nothing back, just maximum charge pressure surpassed...
But it couldn't be the actuator if it's running fine for a little bit everytime the fault is cleared could it?
Offline T_J_G
« Reply #3 on: 15 June 2010, 11:01 »
You not got full VAGCOM Barry? Get some MAF logs done!
Offline Rhyso
« Reply #4 on: 15 June 2010, 11:04 »
Log MAF, MAP (block 110?? 115?) and load - Block 25
Offline barry-gti
« Reply #5 on: 15 June 2010, 11:17 »
Ok. I'll ring the garage and see what they can do... They've got a full VAG-COM...
Cheers!
Offline T_J_G
« Reply #6 on: 15 June 2010, 12:42 »
They going to charge for that? I have full vagcom if you can get te car this way...
Offline barry-gti
« Reply #7 on: 15 June 2010, 12:53 »
Nah they won't charge... I do really owe them a drink though! Been down there a few times and they haven't charged me n I've had no cash to give 'em lol...
Offline barry-gti
« Reply #8 on: 17 June 2010, 16:27 »
Logs were done apparently, not showing no faults I don't think... When we get a chance me n bav are gonna use his map sensor n maf and see what happens!
Offline Rhyso
« Reply #9 on: 17 June 2010, 16:31 »
Can you get hold of the log files at all??
