Author Topic: still got boost problems!  (Read 2635 times)
Offline barry-gti
Re: still got boost problems!
« Reply #10 on: 17 June 2010, 16:58 »
I doubt it, it wasn't on VAGCOM it was on a smaller device... I'll try get some more at some point, what are they supposed to be/look like?
Offline T_J_G
« Reply #11 on: 17 June 2010, 20:19 »
Excel documents ;)
Offline barry-gti
« Reply #12 on: 20 June 2010, 16:39 »
Right...
Me n BaV have changed over his MAF, MAP and N75 to mine and it was still running sloppy. But, I've found a pipe that was supposed to be on top of the wastegate / actuator! so we've put that on and it's a lot better! it doesn't sound like a boost leak no more but it's still overboosting a little...
So i'm assuming now it's got to be actuator??
Offline topher
  • Administrator
  • fully functioning
« Reply #13 on: 20 June 2010, 16:45 »
the actuator vac line wasn't attached? :shocked:
does the actuator rod move smoothly by hand?
Offline barry-gti
« Reply #14 on: 20 June 2010, 17:12 »
We'll have to check that ina minute because it's cooking under there!
Are you ok to talk us through the MAF / MAP logs on VAG-COM if we ring you (if you don't mind, PM me your number)
Cheers mate...
Offline barry-gti
« Reply #15 on: 21 June 2010, 11:41 »
Mainly @ Toph this one...
Do you advise me Tweaking the N75 screw at all? after discovering the 7psi overboost there must be away of tweeking that instead of the actuator or even the map?
Offline topher
  • Administrator
  • fully functioning
« Reply #16 on: 22 June 2010, 00:05 »
no leave it well alone mate .. if swapping n75 with bav made no difference it isn't worth the risk of knackering the n75 and wouldn't help cure a suspected jammed wastegate issue anyway
did you manage to get that log of 118 yet?
Offline barry-gti
« Reply #17 on: 22 June 2010, 07:36 »
We aint had a chance yet mate. To be honest I might just leave it till I'm in the area hopefully in the near future n get you to take a look at it
