Author Topic: Wheel offset help  (Read 1257 times)
Offline mowlamb
  • MK4 GT TDI 130 - DERV POWER!!
Wheel offset help
« on: 13 June 2010, 10:10 »
I've been offered a set of genuine RC's however they have been professionally altered to fit a subaru. My mate reckons they are now ET 43. Is that still ok for a mk4? He also reckons if I add some 5mm spacers to them that will bring the ET back down to the mk4 factory standard. Would that be correct?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wheel offset help
« Reply #1 on: 13 June 2010, 11:07 »
So they have had 5mm milled off the inside? Yes adding 5mm spacers would bring it back to ET38. Better yet add some 15mm spacers for the front and 25mm for the back  :wink:
You'd have to make sure the milling has been done properly though...
« Reply #2 on: 13 June 2010, 14:40 »
They may also have changed the center bore size.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 13 June 2010, 14:44 »
ah yes forgot about that
you really need to try them on the car to see if they centre properly then
« Reply #4 on: 13 June 2010, 14:47 »
Edit just checked Subaru is 56.1, Golf is 57.1 so might not be a problem.
Offline mowlamb
« Reply #5 on: 13 June 2010, 15:46 »
He said they are still 57.1 center bore but I will check before I decide on them. Cheers for the help. :afro:
« Last Edit: 13 June 2010, 15:48 by mowlamb »
