Author Topic: help - engine sounding really rough  (Read 5207 times)
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: help - engine sounding really rough
« Reply #20 on: 11 June 2010, 11:23 »
If a sensor fails it will give a reading similar to what you have
i.e low voltage, bad ground etc
Offline Wurzel
« Reply #21 on: 11 June 2010, 11:38 »
What kind of sensor?
1999 mk4 1.8 n/a AGN Silver Grey
***Looking for one 16 inch wheel, Montreal 2*** and a rear parcel shelf (without speaker holes!)
Offline Hulmie
« Reply #22 on: 11 June 2010, 12:24 »
could be any sensor or even coilpack. Low voltage means the unit is failing. You need a code to pin point what is failing.
Offline Wurzel
« Reply #23 on: 11 June 2010, 12:31 »
But that's the only code I'm getting.
Offline Hulmie
« Reply #24 on: 11 June 2010, 13:31 »
have you tried swapping the coilpacks around and listening closely to see if you notice which is maybe not firing?
Offline Wurzel
« Reply #25 on: 11 June 2010, 14:08 »
Not yet I'll have to dig my Haynes manual out first. I called a local motor factor and asked how much a coil pack would be and they said £64 plus VAT. Might have to risk getting a second hand one on ebay...
Does the non-turbo 1.8 take the same coilpacks as the turbo?
Offline 2001gti4
« Reply #26 on: 11 June 2010, 14:14 »
Try your local VW dealer, they should be chaeaper than that....
My Golf is dead but at least I have this....
Offline Stronz
  • Sold!
« Reply #27 on: 11 June 2010, 14:33 »
I really wouldn't get a second hand one. In the long run it could end up costing you more when / if that fails
Offline Wurzel
« Reply #28 on: 11 June 2010, 14:47 »
True, but I'm going to sell it.
Offline adam 180t
  • mk4 auq
« Reply #29 on: 11 June 2010, 15:02 »
i got a coil pack from panks electrical about 20 quid
