Author Topic: help - engine sounding really rough  (Read 5206 times)
Re: help - engine sounding really rough
« Reply #10 on: 09 June 2010, 19:59 »
As Rich said, I would guess a coil pack issue.
Offline ade_aidy_ady
« Reply #11 on: 09 June 2010, 21:56 »
same problem with me...let me know what the outcome is !
maf or coilpack i think............ will do some logs on maf later with vagcom to check it out....
Offline Wurzel
« Reply #12 on: 10 June 2010, 00:00 »
Where is the best place to get a replacement maf or coilpack if that's what the problem is?
1999 mk4 1.8 n/a AGN Silver Grey
***Looking for one 16 inch wheel, Montreal 2*** and a rear parcel shelf (without speaker holes!)
Offline sicupra
  • boooost!!!!
« Reply #13 on: 10 June 2010, 00:23 »
local motor factor. Poss flea bay but its better to spend that bit extra and get Genuine parts.
no its not strictly a vw.
leon cupra 20vt with a sprinkle of ecotech magic.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #14 on: 10 June 2010, 01:24 »
either a vw dealer or tps get oem vw parts may pay a little more but there the best parts to fit  :wink:
2000 Mkiv GTi 1.8T AGU
Offline Stronz
  • Sold!
« Reply #15 on: 10 June 2010, 09:33 »
+1
I always think it is best to replace all the coil packs at once too - again, makes it a bit pricier, but will  help eradicate any weak spots for the future.
Offline darren1.8t
  • I HATE FRENCH CARS
« Reply #16 on: 10 June 2010, 09:43 »
deff sounds like coil pack m8  :wink:
Offline Wurzel
« Reply #17 on: 11 June 2010, 11:01 »
Code reader arrived this morning, here's the results:
1) Engine - No Codes, although it does flash something very quickly before saying no codes, cant read it's too fast
2) A/T - keeps saying "Link Error" with this one for some reason, quite annoying.
3) SRS - Code: 00532 01/01
4) ABS - No Codes
The booklet says the SRS code means: Transmission control module relay-supply voltage (B+) malfunction low battery or bad ground
Supply Voltage (B+)
So is that saying there's a battery problem? That wont be what's causing the engine problem will it?
Offline Stronz
  • Sold!
Offline Wurzel
« Reply #19 on: 11 June 2010, 11:07 »
Hmm, pain in the ass if it's a wiring thing I'm not good with wiring.
