Author Topic: how much power do you recon?  (Read 2607 times)
Offline dub whore
« on: 02 June 2010, 20:50 »
i have an agu with a ko3s, pipercross filter with hollowed box. forge 007 dv,fmic,forge tip,fully stainless with decat, but still running an r-tech remap from when it was standardo! wot you recon it will run with a new custom map?
Offline topher
  • Administrator
  • fully functioning
Re: how much power do you recon?
« Reply #1 on: 02 June 2010, 20:55 »
200 at the wheels is a general target.. so 220 - 240 at the flywheel
Offline dub whore
« Reply #2 on: 02 June 2010, 21:00 »
well when it was standardo with the r-tech map on then i was told 195bhp so im hoping with all the other mods ill be looking at 240 with a custom map. is that asking too much you think or will i need anymore mods?
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #3 on: 02 June 2010, 21:05 »
with a good running healthy engine with the mods you listed then 230bhp is a reasonable target.
I used to run 198bhp on a AGU with the same mods apart from fmic, then i upgraded to a k03s turbo and now hitting 230bhp and 256lb/ft torque
Offline dub whore
« Reply #4 on: 02 June 2010, 21:10 »
well you say a good healthy engine im just rebuilding an engine thats done 75000miles. its been fully stripped down to bare block and built up again with a good clean and a lick of paint to make her look sexy under the hood. new head gasket water pump cam belt the lot
Offline linz
  • vee-dub
« Reply #5 on: 02 June 2010, 23:10 »
id be very surprised if you got the 220 nick from r tech will tell u the agus arnt the same as the newer lumps so you should aim around the 200-210bhp mark ive got a lot more mods and a k04 and with a rtech remapp i will be looking at 260bhp so wth ur mods an a k03s 240 is very unrealistic on an agu lump
Offline DarkGti
« Reply #6 on: 02 June 2010, 23:13 »
why is it unrealistic linz i made 246bhp on the r-tech rollers
Offline linz
  • vee-dub
« Reply #7 on: 02 June 2010, 23:18 »
from what i got told by nick with a ko4 an all the mods i have uprated injectors ect ect im only looking at 260 so i would hae though to get near tht ud need a few more more thn whathe stated that was all
so with a k03s norm with a remap you get around the 210 mark..... slight more with fmic an a decat
« Last Edit: 02 June 2010, 23:20 by linz »
Offline Purely VAG
« Reply #8 on: 02 June 2010, 23:33 »
I get so bored seeing how much power threads, its been covered 16 times a week on a k03s, then you get people saying "Frank said id get 900 though with my air filter."
bahhhhh...
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline vwfiend
« Reply #9 on: 02 June 2010, 23:48 »
Yep, its all crap. I reckon 260 bhp is awful in a FWD mk4 unless you drive over 80 all the time as 1st, 2nd and 3rd will serve no purpose under full throttle so will be not much quicker on the road than a 220bhp remap. IMO anyway. Plus corners are a bit of a challenge at the best of times. At the end of the day its quick.............for a Golf but not a fast car!
