Author Topic: idle speed  (Read 1892 times)
Offline J4M3S
idle speed
« on: 01 June 2010, 11:55 »
how long should it normally take the idle speed to return to normal after a throttle body clean on an agu? Probably covered about 30 miles since it was done but the idle is getting higher, now goes up to about 1500rpm when sat it traffic?   :sad:
Offline DarkGti
Re: idle speed
« Reply #1 on: 01 June 2010, 12:01 »
prob a couple of hundered miles but after i cleaned mine it idled high for about 2-3 minutes then dropped to about 900rpm
« Last Edit: 01 June 2010, 12:13 by DarkGti »
Offline Deano2711
  • 1992 VR6
Re: idle speed
« Reply #2 on: 01 June 2010, 12:06 »
Mine also took a couple of minutes and runs at 900 rpm.
Offline J4M3S
Re: idle speed
« Reply #3 on: 01 June 2010, 20:22 »
Doesn't sound good then for mine!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: idle speed
« Reply #4 on: 01 June 2010, 21:06 »
have you run an adaptation via VAG COM on the throttle body?
Offline J4M3S
Re: idle speed
« Reply #5 on: 01 June 2010, 21:10 »
it was looked at when the car was in the garage on friday, apparently vag-com just kept kicking them out
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: idle speed
« Reply #6 on: 01 June 2010, 22:21 »
it needs an adaptation really. Was it a VW garage that couldn't get VAG COM to work?
Offline J4M3S
Re: idle speed
« Reply #7 on: 01 June 2010, 22:27 »
No, was my local vag place jbs. Although i've read mixed opinions on whether the agu can be reset or not with vag-com?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: idle speed
« Reply #8 on: 01 June 2010, 22:33 »
yes it can, I have just done mine. It's mixed opinions on whether it does it with the door open trick. It makes the right noises though so give it a go
Put your car into 2nd stage ignition with the door already open but DO NOT START IT. You'll hear the throttle motor buzzing. Leave everything alone (especially the throttle pedal) until the buzzing stops and see how you go after that.
Offline J4M3S
Re: idle speed
« Reply #9 on: 01 June 2010, 22:49 »
Trouble is i don't have a vag-com, so means handing the garage another £50+vat  :shocked:
