Author Topic: idle speed  (Read 2214 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: idle speed
« Reply #10 on: 02 June 2010, 07:14 »
the method above is how to do it without VAG COM
Offline J4M3S
Re: idle speed
« Reply #11 on: 02 June 2010, 07:58 »
Ahh, penny's dropped  :grin:. Will have a try later
Offline Deano2711
  • 1992 VR6
Re: idle speed
« Reply #12 on: 02 June 2010, 09:20 »
I did that with mine after reading it on here and mine was fine virtually straight away. Door open for me by the way  :grin: :grin:
Offline J4M3S
Re: idle speed
« Reply #13 on: 02 June 2010, 11:16 »
no joy for me. Left the drivers door open turned key in ignition, but not turned over, waited for it to stop buzzing then started it up. Didn't work for me  :sad:
Offline Deano2711
  • 1992 VR6
Re: idle speed
« Reply #14 on: 04 June 2010, 12:20 »
Does it not only work for the first time after cleaning ??  You have started the car since and confused it. Try disconnecting the plug and leave it half an hour or so then reconnect the plug and try the door open and ignition on thing. Should solve the problem then Mate.    Good Luck  :wink: :wink:
Offline J4M3S
Re: idle speed
« Reply #15 on: 04 June 2010, 12:37 »
will give it a go mate, although it seems to be steadying itself a bit now  :smiley:
Offline wratey
  • 2000 Mk4 GTI 1.8T
Re: idle speed
« Reply #16 on: 04 June 2010, 13:29 »
i had the exact same problem mate, drove for about 200 odd miles and the idle was still around 1.5k.
i tried everything, in the end i just disconnected the battery, left it for about an hour, reconnected and everything was fine! now idling about 900
