Author Topic: MK1 Cab HU  (Read 1960 times)
Offline mad_allan
MK1 Cab HU
« on: 14 December 2004, 11:47 »
Hi all,
Quick question regarding my MK1 Cab and a HU.
I have a Kenwood HU and 6 disc changer. The ISO is still intact, so I just plopped my HU in and hey presto all works fine.
However, the damn thing is draining my battery. It doesn't actually power off when I turn the ignition off. Even if i remove the face plate so it will be off, it still kills the battery
Any ideas?
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: MK1 Cab HU
« Reply #1 on: 15 December 2004, 07:46 »
You say that the ISO plug is intact, but you need to check that the car is giving out two seperate supplies - one 12v permanent live, one 12v switched live (this should be switched on the ignition).
It sounds like the permanent live in the car is powering both the switch and perm wires of the stereo loom, which will mean that the unit never powers down.
The greatest leveller of them all - the Carousel
Offline AdamB
  • The Perfect Storm
Re: MK1 Cab HU
« Reply #2 on: 15 December 2004, 12:03 »
Kenwood ignition live and permenant live are not compatible with VW. The terminals need to be swapped around, then it will work fine
I don't own this anymore - I just can't be arsed to change the picture
