Author Topic: vagcom fault codes an issues,,, seriously not good :(  (Read 6017 times)
Offline linz
  • vee-dub
well put my baby on the vagcom for first time and  :sad: (as since the upgrade she is just not running right at all she is barely driveable in fact) (im not happy an want it sorted)
some of her problems link to what vagcom said others im baffled the whole car seems to shake uncontrollably at like 40mph  :shocked:
anyway...
oh dear seems i have like 6 engine faults that all lead to maf sensor so guessing i should get a new one.. do i just replace or shud i get the vr6 one as i no i need tht for my live map.
also when upgrading to i get the vr6 housing n sensor or just the housing with a 1.8t sensor?? :embarassed: and do i simply swap them over an thats it?
also i got up like 17 fault codes for central locking  :undecided: havent got a clue what they are all about either
Offline richw911
Re: vagcom fault codes an issues,,, seriously not good :(
« Reply #1 on: 30 May 2010, 20:06 »
Have you got a copy of all the codes?  :smiley:
Offline linz
  • vee-dub
« Reply #2 on: 30 May 2010, 20:51 »
right rich remember you asked for it  :tongue:
engine fault codes -
 Faults Found:
17967 - Throttle Body (J338): Fault in basic settings
            P1559 - 35-10 -  -  - Intermittent
16487 - Mass Air Flow Sensor (G70): Signal too High
            P0103 - 35-10 -  -  - Intermittent
00561 - Mixture Adaptation
            13-10 - Adaptation Limit (Mul) Not Reached - Intermittent
16505 - Throttle Position Sensor (G69): Implausible Signal
            P0121 - 35-10 -  -  - Intermittent
01262 - Solenoid Valve for Boost Pressure Control (N75)
            26-10 - Output Open - Intermittent
            14-00 - Adaptation Limit (Add) Exceeded
airbag codes -
2 Faults Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
01317 - Control Module in Instrument Cluster (J285)
            49-10 - No Communications - Intermittent
instrument codes -
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
            30-10 - Open or Short to Plus - Intermittent
01314 - Engine Control Module
and the central convenience codes -
16 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
01330 - Central Control Module for Central Convenience (J393)
            53-10 - Supply Voltage Too Low - Intermittent
01329 - Convenience System Data Bus in Emergency Mode
01334 - Door Control Module; Rear Right (J398)
01333 - Door Control Module; Rear Left (J388)
01332 - Door Control Module; Passenger Side (J387)
01331 - Door Control Module; Driver Side (J386)
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-00 -  -
            52-10 - Supply Voltage Too High - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
            35-00 -  -
Offline jeynesey
  • Non VW but still VAG
« Reply #3 on: 30 May 2010, 21:14 »
All those door module ones look ominous :sad:
Did they show after you cleared them?
Offline Rhyso
« Reply #4 on: 30 May 2010, 22:18 »
A lot of those simply look as if they've pulled the battery
What codes have come back since you cleared them?
Offline JC
  • Back in the North.
« Reply #5 on: 30 May 2010, 22:23 »
old carz rule  :grin:
Offline linz
  • vee-dub
« Reply #6 on: 30 May 2010, 22:23 »
i did the vagcom like 2 days ago.. an 2 days later there still there im not to worried about the central locking ones im more wrrried about the engine codes
and the airbag one would be nice as the dash light being on is a pain
Offline Rhyso
« Reply #7 on: 30 May 2010, 22:24 »
So you couldn't clear ANY of the codes?  :shocked: :shocked:
It looks to me that they've unplugged nearly everything and not plugged it back in  :undecided:
Offline linz
  • vee-dub
« Reply #8 on: 30 May 2010, 22:28 »
havent done anything about them to be honest  :sad:
as i said ive ignored the central locking ones it works that good enough for me.....
im more concerned about getting my car running right.... as right now its wat i would call undriveable
Offline Rhyso
« Reply #9 on: 30 May 2010, 22:30 »
Have you cleared the codes though?   :huh:
i.e you've clicked the CLEAR DTC button in VAGCOM
Sorry to bang on about it but you're not being very clear if you've done that or not
