Author Topic: hologramming.  (Read 3619 times)
Offline richw911
hologramming.
« on: 30 May 2010, 19:08 »
What causes it? How can you prevent it?  :smiley:
Offline Obvious
Re: hologramming.
« Reply #1 on: 30 May 2010, 19:21 »
I can vouch for one cause, and that's incorrect machine polishing/compounding technique... seen it first hand with one of our butcher valeters at work. (Black car and once it hit the sun  :sick:)
It can be removed, we use 3M Ultrafina to remove most of them, that is when used properly  :laugh:
Offline richw911
Re: hologramming.
« Reply #2 on: 30 May 2010, 19:23 »
Hmmm too much wax maybe also?  :undecided:
Offline Obvious
Re: hologramming.
« Reply #3 on: 30 May 2010, 19:28 »
Yes, wax is a sure fire one, If it's not taken off correctly. In dull light it will look fine, but once you put in the sun it will show as holograms/haze on the car panels, you'll see it clearer by looking at the panel in question and moving your head from side to side. You should see the haze/hologram appear to move.
Best ways to avoid it I would say make sure to use a nice clean microfibre to buff off any product, and make sure product has cured correctly before removing.  :smiley:
Offline richw911
Re: hologramming.
« Reply #4 on: 30 May 2010, 19:36 »
Thank you yeah my thoughts also  :smiley:
Offline VWKev
  • Please Support Non-Human Rights
Re: hologramming.
« Reply #5 on: 30 May 2010, 23:47 »
Holograms are generally caused when Rotary polishing. If you are at the high speed polishing phase when using a Rotary and then stop without polishing out by going down speeds before stopping you will generally put holograms into the paint.
If your getting them and not using a rotary then it beats me how your getting them.
GTI mk6, 3dr Manual (Yes Manual! If I wanted a Taxi I'd hail one, not spend £1500 on one), Candy White, Full Leather, Xenons, ACC, 18", RCD510 + Dynaudio, DAB Radio, Winter Pack, Luxury Pack, Fiscon Bluetooth Plus, Golf R LED's.
"Some say he drives a Shopping car, and that his car dent was actually a beauty spot....all we know is he's called Captain Failboat"
Offline Kyle!
Re: hologramming.
« Reply #6 on: 11 June 2010, 22:00 »
sorry for the daft question but whats holograming?
http://uk-mkivs.net/forums/p/473515/3251643.aspx#3251643
^^ Clicky For Build Thread (Updated 17/08/12) ^^
Offline Guy
Re: hologramming.
« Reply #7 on: 11 June 2010, 22:13 »
in short...
the easiest way to explain it is that it is like a spiders web on your car when it is clean and in direct sunlight
Offline Kyle!
Re: hologramming.
« Reply #8 on: 11 June 2010, 23:51 »
thank you!
mine has this but ive never machined it, just hand polished it do i need to buy a machine??
Offline Dan J
Re: hologramming.
« Reply #9 on: 12 June 2010, 01:27 »
the main factor of causing holagraming by machine is too much pressure or uneven pressure.
