Author Topic: Loud On Start ??  (Read 1901 times)
Offline tech1889
  • Mk2 GTI FTW !!
Loud On Start ??
« on: 30 May 2010, 14:31 »
Hi ive got a 1.8t AUM 2002 and every time i start it, it idles quite high (1300rpm or so) for about 45 seconds to a minute or so and then drops to about 950rpm. It only does this from cold but it does it every time i had a fiesta before this and it only done that when it was really cold outside like winter time not in the summer. Is this normal or not ? And if not is there a way to rectify this ?
Many thanks
Tech1889
Offline T_J_G
Re: Loud On Start ??
« Reply #1 on: 30 May 2010, 15:27 »
Normal, mine does it.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 30 May 2010, 15:38 »
oh ok is there any reason for it though do you think ??
Offline ggggolfgti
« Reply #3 on: 30 May 2010, 16:20 »
its meant to do it, it has an air pump and secondry air intake, its basically there just to help the car start when outside temp is low
249 bypass, ths fr3 engine mounts, S/S decat, 2.5'' straight through exhaust, induction kit, forge split r, coilovers, 18'' alloys, much more in the pipeline
Offline Big Tone
« Reply #4 on: 01 June 2010, 12:58 »
Think its to warm the CAT up. prior to moving off.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Waffs1984
  • Spacers are for chumps...
« Reply #5 on: 01 June 2010, 14:20 »
Yes it is it helps prolong the life of the CAT by passing extra air through it on startup, also has something to do with reducing emissions (obviously linked to the CAT) on startup - VW are incapable of designing something purely to make a component last longer  :lipsrsealed:
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #6 on: 02 June 2010, 11:25 »
oh right i just thought it was a bit funky but it makes sense now  :smiley:
Offline Big Tone
« Reply #7 on: 02 June 2010, 12:39 »
Many thanks
Tech1889
Does it make a "Whoosh" sound when it cuts out? if so, need to replace the rivets in the pump, easy job, loads of info around.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #8 on: 02 June 2010, 22:02 »
nope it just slowly drops down the revs with no other noise just getting quieter. so no changing of the rivets hopefully :)
« Reply #9 on: 03 June 2010, 09:07 »
Normal.
