Author Topic: Rev counter for a Mk2 Driver?  (Read 1680 times)
Offline KieranC
« on: 12 December 2004, 23:03 »
I've just got a 1989 Mk2 Driver 1.6 carb, but it's got a clock where the rev counter should be.
does anyone know if these would work in place of the current guages?
Re: Rev counter for a Mk2 Driver?
« Reply #1 on: 17 December 2004, 17:36 »
Yes :)
But only if your car has the 2 plug clock type:
Hazard switch on dash = old CE1 = 2 plugs
Hazard switch on steering column = new CE2 = 1 plug
You can swap your old speedo into the new clocks easily, just a few screws and you need to swap the 'L' shaped circuit board and a small electrical sender screwed into the back of the GTI cluster, yours will have a planking plug over the hole which you just push out!
Offline sesterfield
« Reply #2 on: 05 January 2005, 13:39 »
Sorry to bump an old topic but I didn't think it was worth starting another one :P
Does anyone know if it's possible to fit a set of clocks with a rev-counter to a 1990 1.3 Golf?
« Reply #3 on: 05 January 2005, 13:43 »
Yup same info still applies, get a set with the right number of plugs on it :smiley:
Offline sesterfield
« Reply #4 on: 06 January 2005, 14:29 »
Awesome, thanks  :cool:
