Author Topic: Which bar oil pressure switch, mk2 16v 1991 model  (Read 9857 times)
Offline walchy01
Hi there
could anyone advise me bar pressure switch I need as the dealer is showing 4 options, the one I have picked up is 0.15 to 0.35 pressure switch, us this correct for my car, looks completely different from the one I'm changing it for in size terms.
Thank you
Offline walchy01
Re: Which bar oil pressure switch, mk2 16v 1991 model
« Reply #1 on: 27 May 2010, 13:38 »
Anyone please
« Reply #2 on: 27 May 2010, 13:42 »
depends which switch you need to replace! blue or brown is for the low pressure 0.3bar, white is 1.8 bar high pressure
Offline walchy01
« Reply #3 on: 27 May 2010, 14:31 »
it's this one rj at the back right corner of the head, with a green and black wire going to it with a spade connector on the end
hope that helps
thanks in advance again for ur brilliant advice :grin:
Offline walchy01
« Reply #4 on: 27 May 2010, 14:34 »
This is what the main dealer supplied, doesn't seem anything like!!!
« Reply #5 on: 27 May 2010, 14:36 »
thats an oil temp sensor not pressure!
Offline walchy01
« Reply #6 on: 27 May 2010, 14:37 »
Main dealer one
Offline walchy01
« Reply #7 on: 27 May 2010, 14:39 »
Where this go then rj, now I've got I may as well fit it, thanks again and sorry for my ignorance, still learning  :huh:
« Reply #8 on: 27 May 2010, 14:40 »
that one goes on the oil filter housing, replaces the sensor thats brown or blue with a blue wire :)
Offline walchy01
« Reply #9 on: 27 May 2010, 15:26 »
Rj has the oil temp sensor got any connection the mfa stalk reading for the oil temperature, cos that's what I am trying to resolve, mfa showing no oil temp reading just shows ---
thanks
