Author Topic: Which bar oil pressure switch, mk2 16v 1991 model  (Read 9858 times)
Re: Which bar oil pressure switch, mk2 16v 1991 model
« Reply #10 on: 27 May 2010, 15:34 »
sure does, thats what its for :)
it will display --- till the oil temp gets to around 50 degrees. to check if its trhe sensor at fault earth the wire, it should read about 150degrees on the MFA
Offline walchy01
« Reply #11 on: 27 May 2010, 16:14 »
Sorry for being abit dum again but how do I earth the wire??? To what exactly, thanks for top advice again
russ
« Reply #12 on: 28 May 2010, 08:20 »
touch the spade connector to earth somewhere, a handy place to earth it would be the engine block :)
Offline walchy01
« Reply #13 on: 29 May 2010, 12:09 »
Fitted new sensor for oil temp, now working spot on, wicked
Offline walchy01
« Reply #14 on: 01 June 2010, 18:00 »
What do the 2 switches actually do please???
« Reply #15 on: 02 June 2010, 10:23 »
oil pressure warning. brown/blue one brings the oil light on if pressure drops below 0.3bar at idle, white one brings on buzzer and oil light if pressure drops below 1.8 bar from around 1.8-2k rpm +
Offline walchy01
« Reply #16 on: 02 June 2010, 16:38 »
Thanks rj, love learning all this new stuff :wink:
Offline BJD
  • G2 GTI 16V - G4 TDI 130
« Reply #17 on: 12 March 2012, 22:01 »
Didn't want to start a new thread, but i've searched all night and cant find my answer. So i though i'd dig this one up.
Im having trouble with my oil pressure switch on my 16v. Reading RJ post about blue/brown and white makes me wonder if i have to wrong switch fitted. Heres a picture....
Ive found a brand new blue switch with loads of stuff that came with the car. Should i change the black one with the new blue one?
Any help appreciated
Offline Santiago
« Reply #18 on: 13 March 2012, 09:58 »
Yep.  :smiley:
Offline BJD
« Reply #19 on: 13 March 2012, 10:11 »
Yep.  :smiley:
Is the black one wrong then? Cheers
