Author Topic: Golf Gti Mk3 - Work Horse  (Read 180056 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: Golf Gti Mk3 - Work Horse
« Reply #190 on: 14 November 2011, 21:07 »
ha this looks cool mate
how did you stick the headliner down? any issues with it sagging etc ??
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline stow1985
  • 'when im cleaning winders'
« Reply #191 on: 14 November 2011, 21:40 »
Thanks mate, i used spray adhesive, and its sagging badly...ive done one section with pva glue and it has done the trick, so pva is the way  :grin:
Offline stow1985
« Reply #192 on: 17 November 2011, 23:02 »
Ok bit of an update....
after reading through benvictors project (which so cool) brought my attention to de-cating my exhuast using a broom....so i decided to give it a go, and if it didnt make any difference i haven't waisted any money....but im glad to say i think its solved the problem, will wait and see how she starts in the morning
Offline stow1985
« Reply #193 on: 20 November 2011, 10:59 »
Hi all,
As some of you know my car (MK3 GTI 8V) hasn't been running to healthy recently, but after a bit of head scratching, autodata reading and some multimeter probing  :rolleyes: I've managed to find the fault...temp sender or (ECT) Engione coolant sensor as is says in the auto data book...
Autodata: 80*C - 325ohms
Mine:       80*C - 149ohms :sad:
I wanted to know once I've changed sensor do you need to reset the ECU? disconnect the battery? remove Fuse? or is it a simple swap over and let it sort its self out???..
Thought id post it here too... so the cat wasn't the problem, but hey its let out some more ponies in the process and it was free :smiley:...hopefully will get the new temp sender later this week....
Offline stow1985
« Reply #194 on: 10 December 2011, 09:45 »
Oh well still haven't got my new sender, Christmas is draining all of my funds  :rolleyes:
Found these pics from the summer:
Thats my boi!  :grin:
Offline Seanl
« Reply #195 on: 10 December 2011, 13:21 »
Love how you get the little un' involved nice and early in life!  :grin:
Oh, and have a shave!  :lipsrsealed: :grin:
Offline stow1985
« Reply #196 on: 10 December 2011, 23:19 »
More he gets involved the more time i spend on the car  :grin: :grin:
Cheeky Sh*t!!  :rolleyes:
Offline stow1985
« Reply #197 on: 30 December 2011, 10:33 »
I have finally FINALLY bought a new temp sender, made a big difference to how she drives, much smoother and better MPG...
another problem has revealed itself (to be honest I thought the temp sender would or solved this), when I first start the engine she wont idle, just stalls, so I have to hold the revs for about a minute before she idles nicely...and...if she does stall it struggles to start again, is it me or does this sound like a coil...AGAIN?
Old   :sad:
New  :smiley:
and one of the rear  :wink:
any comments or suggestions on the poor idle?
Offline SoundillusioN
« Reply #198 on: 30 December 2011, 11:41 »
 :grin: Reminds me of
Not sure what your idle issue is but I doubt it's your coil...  Have you checked that it has a healthy spark?
Offline stow1985
« Reply #199 on: 30 December 2011, 19:43 »
Almost like twins  :laugh:
I think the sparks fine as it runs ok apart from the initial start, been having a little think :nerd: over the course of the day and Im going to clean out the ISV in the morning see if that helps...
