Author Topic: Toyo R888's  (Read 12751 times)
VeeDubGTI16v
Re: Toyo R888's
« Reply #10 on: 26 May 2010, 11:34 »
you should be ok, the 928 days seem very relaxed. Dont remember even getting sound tested at silverstone?
the general rule though is slicks need a cage, as you mentioned
my r888's are looking very worn, i was gonna keep the fronts on the front and wear out 2 at a time, but now the prices have gone up im gonna run them backwards on opposite corners for combe, wear them all out and look for a different tyre
« Last Edit: 26 May 2010, 11:36 by veedubgti16v »
VeeDubGTI16v
Re: Toyo R888's
« Reply #11 on: 26 May 2010, 11:56 »
Has anyone looked at or tried or read any reviews on the new Toyo R1R's (semi trackday tyre)
They look good but not a lot cheaper than r888's, so i don't really see the point. They look like they will be a bit better in the wet though
Offline Diamond Hell
  • Opinions я Us
Re: Toyo R888's
« Reply #12 on: 26 May 2010, 13:26 »
as marshalls do get upset with you overtaking in corners and thats where the syncro make's most ground and if allowed would overtake most stuff.   so thinking if i have  less grip i'll be slower but maybe more fun
I have a video featuring a black flag resulting from that problem.
It's totally dependent on the track, nothing to do with the organisers.  Goodwood are epically anal, Combe are reasonably keen too - both on Richard's events.  At Combe you won't get on track without your noise test sticker and you'll only get that by going through the noise-test shed and talking to the old duffers.
T1-Rs are OK unless it's searingly hot.  Under normal conditions you'll roll rubber off the tyres, if it's proper hot they'll go off halfway through a session, leaving you wondering where all your grip went.
As I understand it there have been some issues with the early R1-Rs.  We're likely to see more of their ilk in the future, as there's talk about 'track day tyres' being legislated off the market.  Understandable given their standing water performance.  :grin:
Offline Horney
Re: Toyo R888's
« Reply #13 on: 26 May 2010, 14:04 »
Silverstone decided not to bother and were only going to throw anyone off if they failed the drivebay ones they have out on circuit.
Castle COmbe is 100dB I think, lol @ the old duffers comment DH.
Nick
Offline s1monc
Re: Toyo R888's
« Reply #14 on: 26 May 2010, 14:18 »
Just dug out my invoice from Tyretraders dated Feb 2010, i bought x4 R888 in 195/50/15 for £247 del which works out at £61.75 each inc del !!! What a deal that was :smiley: Did a trackday 2 weeks ago & now my n/s/f tyre is illegal but the problem i have is i don't have a spare set of wheels with road tyres yet as theirs loads more wear left in the tyre for trackdays.
Simon.
Offline Horney
Re: Toyo R888's
« Reply #15 on: 26 May 2010, 14:33 »
Wha compound where they? You shouldn't kill one in a day on a Golf unless your tracking is badly out like mine was.
Nick
Offline s1monc
Re: Toyo R888's
« Reply #16 on: 26 May 2010, 15:41 »
Yes the tracking is out, i had the whole front end in bits to renew bushes,coilovers,weld wishbones,trackrod end,driveshaft gaitors etc etc & have not had any alignment done yet :huh:because i have to remove a faulty strut/coilover again 1st & sort that before alignment, i think its toeing out by the looks of it. They were SG compound too so won't last as long, the other 3 tyres are ok, o/s tyres have hardly any wear.
Simon.
Offline Horney
Re: Toyo R888's
« Reply #17 on: 26 May 2010, 15:45 »
Simon.
Doubly whammy then! I've been told a pair of SG fronts will only last one or two trackdays at best. I got 3 out of my front GG's and they'd also done the ring and several other trackdays in the hands of the last owner. One of them still has 50% tread but the outside one is dead as like you I ran with the tracking not set correctly.
Nick
VeeDubGTI16v
Re: Toyo R888's
« Reply #18 on: 26 May 2010, 17:10 »
http://www.camskill.co.uk/products.php?plid=m12b0s662p4057
anyone tried these? £50 a corner they might be worth a try  :huh:
Offline Horney
Re: Toyo R888's
« Reply #19 on: 26 May 2010, 17:14 »
