Author Topic: Rear knocking noise over bumps  (Read 7628 times)
Offline Kwok8
« on: 20 May 2010, 20:23 »
Lately been hearing a slight knocking noise going over speed bumps coming from the rear suspension area.
Does anyone know what this could be? Brushes?
Offline AlanD
  • MK5 2.0T 16v
Re: Rear knocking noise over bumps
« Reply #1 on: 20 May 2010, 20:36 »
Sounds like bushes.
My sister had an identical problem in her TT with the speed bumps in our area and it was the bushes.
Offline Kwok8
« Reply #2 on: 21 May 2010, 20:37 »
Does anyone know how much this would cost to fix?
Don't really want to go dealers. Maybe a specialist in the midlands.
Offline Hurdy
« Reply #3 on: 21 May 2010, 20:43 »
Bushes don't cost too much. It will be labour what stings. An independant would probably do them for a couple of hours labour max.
Looking at under £200.
Where in the Midlands are you?
Seat Leon Cupra Black 290 DSG
Offline Kwok8
« Reply #4 on: 21 May 2010, 21:42 »
South birmingham.
Someone has recommended Midland VW.
But my car is 3.5 years old and done 33k, should bushes be knackered already?
Offline dTEA
  • back in an MK5
« Reply #5 on: 21 May 2010, 23:40 »
Yeah on speed bumps but get the polybushes fitted if you want longevity. You might as well get the fronts done at the same time...but not boththe inner n outer I remember write
Edition 30 / T5 T32 Kombi
Offline Brush57
« Reply #6 on: 22 May 2010, 00:10 »
I had the same problem with my ed30 and it was the stricker for the tailgate try a bit of duck tape round the stricker that should stop the knocking noise. Hope this helps
2012 Black Edition 35
Offline Stitch
« Reply #7 on: 26 May 2010, 07:59 »
HD my rear bushes replaced under warranty following the same symptoms.
Offline jaydubveedub
« Reply #8 on: 26 May 2010, 16:05 »
Yeah, the rubber knobs on the parcel shelf strings do sound a bit like suspension knocks when you go over bumps.
Whip your parcel shelf out for a bit and see if the noise is still there.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline luvmygti
« Reply #9 on: 01 June 2010, 11:25 »
Mine doesnt knock, but it creeks like a b!tch  :sick:
MKV GTI/ 3 Door/ 18" Monza II/ Full leather/ heated seats/ Manual/ Arm rest/ 6 Disc changer/ Cruse control/ Highline MFD/ Xenons/ Dog's Nuts!
