Author Topic: Rear knocking noise over bumps  (Read 7629 times)
Offline flyingzard
Re: Rear knocking noise over bumps
« Reply #10 on: 02 June 2010, 23:49 »
I had a similar knocking noise that sounded like it was suspension. There is an old thread in the (18 months ago now maybe).
Turned out to be a defective locking mechanism for the boot. Once that was replaced the noise never came back. I wouldnt be surprised that you have the same thing.
Offline Colinv
  • Qualified VW mechanic
« Reply #11 on: 07 June 2010, 19:48 »
Hi mate I'm a vw mechanic to trade and there's a good chance that if the boot or parcel shelf removal doesn't cure the noise, the rear arms bushes could be worn, we've done loads at work. There not bad to do but you will see the 18mm bolts behind the rear anti roll bar and 21mm nuts and bolts at the hub end. You may need to exhaust slid to one side and definitely need to rear anti roll bar out the way to access them
Offline adamfernadam
« Reply #12 on: 10 June 2010, 21:36 »
Id take a guess at the bushes...use independants though..or ebay..should get decent ones for a good price..then find a mate who knows what hes doing to save the labour lol
