Author Topic: g60 flywheel lightening  (Read 7685 times)
Offline danny_p
Re: g60 flywheel lightening
« Reply #20 on: 22 May 2010, 01:15 »
its pointless spending money having the flywheel balanced up f everything that either bolts to it or it bolts to isnt balanced up aswell.
thats a bit daft,  every thing is balanced.  better balanced the rotating parts of an engine are the more efficent and longer lived it'll be.   unbalanced flywhell will just strain the crank and main shells as it trys to wobbel
my flywheel is lightend,  idel affected no, drivablity affected no.   made the car a bit nippyer.
all the VW's have gone bar 1.
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #21 on: 22 May 2010, 08:35 »
sorry may have not made myself clear. I know the pparts will already be balanced. but everything will be balanced to suit old set up. I ment get the other parts balanced up to match the new lightened/balanced flywheel.
Offline Dave_IOW
« Reply #22 on: 22 May 2010, 11:27 »
Well im going to go ahead with it, can get it lightened free and balanced for 30quid, and for half a tank of fuel its worth a go. Ill let you know results if anyones interested  :smiley:
Maybe it wont all be balanced together but surely putting a normal g60 on without lightening, it wouldnt be balanced to crank etc either?
Difference is mine would be lighter and not balanced to the crank/case whereas normal g60 installation would be heavier, not balanced aswell etc?
I have ABF one which weighs 10.5kg think heavier than g60 one anyway as heard thats 9.5kg? Going to take it down to 8kg. Any idea what yours weighs in at danny_p?
Quote
Contrary to popular belief it's certainly not necessary, or even always helpful, to balance a flywheel on the crankshaft it's going to be used on except perhaps for extraordinarily high revving and delicate race engines. Unless the flywheel is tightly dowelled to the crank it's going to sit in a slightly different place every time it's fitted anyway. There will always be a small amount of play between the crank spigot the flywheel sits on to centralise it and also between the flywheel bolts and their holes in the flywheel. Now we're only talking a thou or so of possible movement but that's enough to make it pointless trying to achieve any better level of accuracy than by balancing the flywheel on a proper mandrel in its central hole. At least you then know the flywheel itself is in perfect balance and it will run very close to that on any crank it's then fitted to. That's certainly the way all production flywheels are balanced anyway.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Dave_IOW
Re: g60 flywheel lightening *pics*
« Reply #23 on: 29 May 2010, 14:37 »
Ok so update, flywheel was ABF one and weighed in at 10.5kg, had this skimmed down to 8kg on mandrel on lathe.
Should be balanced somewhen next week!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #24 on: 29 May 2010, 15:40 »
will be interesting to see how this compares to mine...
Offline Dave_IOW
« Reply #25 on: 29 May 2010, 19:41 »
Gotta get the turbo fitted first but yeah  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #26 on: 29 May 2010, 21:59 »
are you fitting it yourself? Or you too scared  :grin:
Offline danny_p
« Reply #27 on: 29 May 2010, 22:22 »
mine was taken down to 6kg
Offline Dave_IOW
« Reply #28 on: 30 May 2010, 15:15 »
Fitting clutch n flywheel but gunna get r-tech to fit turbo maybe.
My agricultural friends are good with the spanners, but are more like the scrapheap challenge contestants than mechanics  :laugh:  :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #29 on: 30 May 2010, 17:34 »
bah get on it, won't take you long :wink:
