Author Topic: GTI Owners On REVO  (Read 4592 times)
Offline KennyGTI
GTI Owners On REVO
« on: 20 May 2010, 08:56 »
What map did you go for? 95 Ron or 98/99 Ron? I have the 95 Ron map but thinking in changing to 98/99 Ron as thats the fuel I use. Guy forgot to ask me and I forgot to say when I was getting it done, was more interested in seeing if it worked or not. Not sure if I am maybe safer sticking with the 95 Ron for now until i get my exhaust and induction fitted.
APR Stage 2+
Offline R32UK
Re: GTI Owners On REVO
« Reply #1 on: 20 May 2010, 09:23 »
I am running on 99ron. Not sure what the other settings are on though :undecided:
Offline KennyGTI
« Reply #2 on: 20 May 2010, 09:58 »
What do you mean by other settings?
Think am going to leave it on 95 ron just now and change it to 99 ron when am getting my exhaust fitted. Not wanting wanting to go stage 2 until I have the Forge Twintercooler on.
APR Stage 2+
Offline R32UK
« Reply #3 on: 20 May 2010, 15:30 »
iirc - boost, fuel, and timing i think is the last one. These can only be changed if you went for the select + option. I have the select switch but not the software to change the settings.
http://www.revotechnik.com/products/selectPlus.aspx
Offline jdjd
« Reply #4 on: 20 May 2010, 20:16 »
Currently running in the number 4 switch position. Put some of that Octane booster sh!t into my tank lasttime I filled up. Says +4 octane so ide be running fuel at 103 octane rating. Seems to be alot better on economy when chilling. Seems abit more noise from engine under acceleration. Is it faster? Im not sure. Would I spend the £10 again on the stuff. Prolly not no. had to try it tho
Offline FroGTI
  • Wheel nut
« Reply #5 on: 21 May 2010, 05:43 »
I'm on 99, too. I was told the 95 setting would give about 20hp less. I filled up with 95 (on the 99 setting) once just to see and it felt more like 30hp less.
Offline Neil gti
« Reply #6 on: 22 May 2010, 22:27 »
Mine is set up running on optimax is there any other fuel  :grin: and she goes like the wind  :rolleyes:
A cheeky pic of her chilling out today at the seaside   :grin:
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline SteveP
« Reply #7 on: 22 May 2010, 22:34 »
98/99 RON map for me too.
And if Neil can pic whore, so can I  :laugh:
Offline Neil gti
« Reply #8 on: 22 May 2010, 22:47 »
Nice pic Mr P.     you whore you  :grin:
Is that at the ring ? No helmet needed  :shocked:
Loving the 7R
Offline SteveP
« Reply #9 on: 23 May 2010, 20:33 »
^^^ Yep at the ring, and no a helmet is not required for getting on the track. :smiley:
