Author Topic: 11mm Spacers, do i need longer bolts???  (Read 3509 times)
Offline marty341
  • To ko4? or to not Ko4? now that is the question.
« on: 19 May 2010, 09:52 »
Guys/girls, im looking to fit some spacers, 10-11mm to my car, ive just got some new rims, there 8x18s with e45 offset!
Will i need to get different bolts? or will the new one's coming with the new rims be ok?
The car is lowered around 40mm also! any input would be much apprieciated :smiley:
Revo Stage 1
Re: 11mm Spacers, do i need longer bolts???
« Reply #1 on: 19 May 2010, 11:05 »
Yes you will need longer bolts.
Offline S2 Ant
« Reply #2 on: 19 May 2010, 11:06 »
Yes deffo will need longer bolts
Offline marty341
« Reply #3 on: 19 May 2010, 11:40 »
Cheers Wayne, Ant :smiley:
Thought so, need to get on it then! new rims arrive tomorrow, fingers and toes crossed!
Revo Stage 1
Offline Hurdy
« Reply #4 on: 19 May 2010, 20:20 »
Have you got anything that will get you extra negative camber?
10/11mm spacers and a wider wheel and a lower offset and lowering - you putting narrower tyres on for stretch?
Normal tyres will rub with that combo if you don't have the option to adjust camber!!
21.5mm extra poke over stock with the spacers!
MAY just get away with them on the rear :wink:
Seat Leon Cupra Black 290 DSG
Offline TrickGTI
« Reply #5 on: 19 May 2010, 20:24 »
hey just on the 40mm lowering thing whats that sit like because mine is standard i was looking at the gap between the wheel and arch and 40mm seems like alot i dont like it when the wheels disappear behind the arches and you carnt see the top of the wheel, whats the perfect amount for the wheel to just follow the arch nicely???
cheers
Offline marty341
« Reply #6 on: 19 May 2010, 21:32 »
No wont be able to adjust the camber Hurdy! there a 8" alloy with 225 rubber!
Im thinking 5mm fronts, 10mm rear, do you think this will be fine? :smiley:
I
Revo Stage 1
Offline marty341
« Reply #7 on: 19 May 2010, 21:55 »
cheers
Trick, the eibach pro springs give a drop of 40mm, but to be honest the wheel arch gap has only reduced by around two fingers width! so doesnt look slammed, and the ride quality is ace :wink:
Just didnt like the SUV stock appearance, esp on 17"s Monza's :sick:
Not to harsh, cant wait to get 18"s on her :smiley:
« Last Edit: 19 May 2010, 22:01 by marty341 »
Revo Stage 1
Offline Hurdy
« Reply #8 on: 19 May 2010, 21:59 »
Try the new wheels without any spacers at first and lower it. If you get away with no rubbing when lowered, add 5mm spacers at the rear 1st(easiest to get away with), then 10 mm spacers on the rear, then swap the 5mm spacers to the front and try them. You may find that you'll settle for 10mm at the rear and no spacers at the front. :wink:
Offline TrickGTI
« Reply #9 on: 19 May 2010, 22:01 »
awsome thats great. iv got the 18" standard gti wheels on so thats one bonus  :grin: from looking at your pic the car looks so much better for such a suttle difference. me thinks some of those billy bad boys will be on order soon
cheers
