Author Topic: 20vt mk2 sleeper project.written off :(  (Read 224508 times)
Offline cняis
Re: project £500 (body finished pg6)
« Reply #90 on: 07 September 2010, 22:04 »
It failed. Bugger.
Low effort on handbrake, small patch required to floor, couple of brake pipes and hoses, rear tyres not mounted correctly.
Going to sort it tonight all being well. Wheel wise i'll put my bbs rx's on for now while i source some narrower wheels for the rear.
Booo, unlucky mate... at least its not a big list.... good luck with sorting it out.
cheap fixes mate, chin up! :afro:
Offline lewis1641
  • stuck in the 90's
« Reply #91 on: 08 September 2010, 14:48 »
the list was a little bigger than that!
cleared blockages and adjusted washer jets (easy but took ages and got soaked), checked and swapped a few bulbs,passenger seat and carpet out ready for welding, and swapped the wheels over.
its off for retest tomorrow. hope the handbrake goes through because it isnt a lot better than it was...
the car now looks really wierd sat on the bbs wheels. they are off a 6n polo gti so are a high offset so they sit right into the arches. they look totally lost. if they arer staying i'll be getting some 20mm spacers on there!
i am half tempted to run the porsche wheels as they are untill i get pulled for them (stretched tyres being a grey area) but i am getting a bit old for that so i'll probably try and find another pair of fronts. its a pity they dont seem to make them in et53 and 8 inch wide. c'est la vie
Offline lewis1641
  • stuck in the 90's
« Reply #92 on: 18 September 2010, 20:01 »
Well it's passed the mot.
Now i can start on the bits i've been meaning to do for ages.
Immediate jobs-
Clean up calipers, paint them up and reassemble with plenty of copper grease
Clean the engine bay. It's an embarassing mess.
Sound deaden the doors, new plastic sheets then finally get the door panels back on.
Get the driver's side seat bolsters repaired and reupholstered. But that'll be a longer term job.
Exhaust needs 1 new clamp
Bumpers need straightening up.
Steering wheel and stalks need squaring up
Heater matrix needs replacing i think. My mechanic mate's apprentice has offered to do that for 20 quid so i'm going to spare myself the frustration of cocking it up
Front wings are coming off again. I bent them taking them off the donor car and they don't fit very well now. When i fitted them i didn't really care or notice as we were rushing about but it's playing on my mind now.
Also need new wheels i think. Can't deal with the offset on the rx2's and as nice as they are they are a bit too subtle.
So still plenty to keep me occupied for a while.
Offline SoundillusioN
« Reply #93 on: 19 September 2010, 12:11 »
Glad you got her through the MOT, thats great!... worst bit of the way for sure... the rest might not feel so stressful.  keep up the good work.
Offline lewis1641
  • stuck in the 90's
« Reply #94 on: 22 September 2010, 13:30 »
cheers man. interior is almost back together. i say almost as i have lost half of the fixings for the door handles and the rubber strip on the 0/s/r doof  :angry:
« Reply #95 on: 22 September 2010, 14:29 »
Oh god youve got me thinking now!..... i bet i come a cropper too.. i started off really carefully but it soon piles up!
Offline Dec
« Reply #96 on: 22 September 2010, 14:33 »
Cars looking ace!
Sorry to hi-jack, did the car fail the MOT because of stretched tyres? :undecided:
Offline lewis1641
  • stuck in the 90's
« Reply #97 on: 22 September 2010, 16:38 »
Cars looking ace!
dont consider that a jikack dude.
the tyres were one of the fail points. i could have argued the point but it was far easier to stick some mk2 wheels and tyres on.
on the fail sheet it gave the reason as "tyres incorrectly mounted" and "tyre interferring with bodywork"
the tyre wasnt catching the body, it was the rim itself!
as for being mounted incorrectly, the bead is sitting in the right place and as the  tyre fitter says, if it isn't mounted properly then it wouldnt hold air or suipport the weight of the car.
anyway the issue is that particular tester failed it. it has made me a lottle nervous about running it as it is though...
Offline lewis1641
  • stuck in the 90's
« Reply #98 on: 22 September 2010, 16:48 »
i thought i was careful! got most of them and i have my suspicions that the rubber strip has been liberated for someone else's car...
but i cant go around accusing people of stuff.
Offline Sam
  • Sam I am
« Reply #99 on: 22 September 2010, 17:03 »
I blame your mate who has a vw garage...
