Author Topic: 20vt mk2 sleeper project.written off :(  (Read 200421 times)
Offline tsr_adi
Re: project £500 new wheels (again)
« Reply #440 on: 29 December 2010, 13:28 »
Do the K-jets have the little coil related box on the ECU heatshield (I know they don't have an ECU but the carb models still have the heatshield with a little box and a wiring plug on them.) Its common for this to cause no spark on the carb models. If yours has this then I have a few working spare ones. If its stinking of fuel then I hope for your sake its got no spark, then it could only be a few things, like plugs, leads, dizzy, coil etc, all fairly cheap items.
Offline lewis1641
  • stuck in the 90's
« Reply #441 on: 29 December 2010, 14:29 »
my sentiments exactly!
cheers adi. i'll check for the box. its parked up at my mates house at the min so cant really do a lot. will recover it on saturday.
Offline Bellend
« Reply #442 on: 29 December 2010, 16:04 »
Is this SPi? Sorry I haven't really flicked right through.
If it is, check the throttle body injector, same symptoms as my dads, stank of fuel, turned out the injector had moved up and was dumping fuel straight in off the fuel pump.
Where all my moneys went.
Offline SoundillusioN
« Reply #443 on: 29 December 2010, 16:31 »
Yes they do, this only came up in the mk1 section a couple of days ago.  The Hall unit??
Shaun
Offline lewis1641
  • stuck in the 90's
« Reply #444 on: 30 December 2010, 09:53 »
What is spi dude? Edit. Single point injection? No its kjet
I think the thing you two are on about is attached to the offside suspension mount.
Had a go at firing it up last night and we nearly got there but the battery was failing. Hooked it up to jump leads and it fired but only 1 cylinder. Eventually got 3 going then let it warm up and the fourth fired.
Then it stalled! When i struck it up again my mate spotted the plug leads sparking. Bingo
Offline lemski
  • 16v
« Reply #445 on: 30 December 2010, 10:17 »
Good job dave. She lives again then?
Offline Peej1981
  • Its Whats Under The Hood That Counts........
« Reply #446 on: 30 December 2010, 11:01 »
Glad to see she is alive again, at least it looks like it wasnt anything serious or costly. :grin:
www.bombercountydubs.co.uk
Offline tsr_adi
« Reply #447 on: 30 December 2010, 18:51 »
good news!
Offline Peej1981
« Reply #448 on: 30 December 2010, 22:07 »
Dave is it all running ok now???? Anyway all bomber county dubs check the linclnshire thread out, just uploaded the club sticker design, sorry dave for the hijack here  :grin:
Offline lewis1641
  • stuck in the 90's
« Reply #449 on: 08 January 2011, 09:51 »
just a very brief update. a few pages back i mentioned swapping the eibach rear springs for some chopped mk3 ones as i had suspected the eibachs had gone soft. at the time the roads were a mess so couldnt tell how it had affected the handling.
it has now had a couple of twisty drives. and it feels the same! so i suspect either a, rear sus makes very little difference or more likely b, the eibach springs are goosed and therefore performing as well as chopped mk3 driver springs!
