Author Topic: 16v cutting out ????  (Read 2643 times)
Offline phil t
« on: 06 December 2004, 19:17 »
My 16v, with only 75k, has a sad habit of cutting out when coming up to a junction. Foot on clutch, ignition lights come on, engine cuts out. Unfortunately, its intermittant, and feels as if I could get the clutch down further, it wouldn't cut out, but I know the clutch is self adjusting properly.Its just been serviced (professionally), which unfortunately has not made a difference. I've tried using injector cleaner etc, but to no avail..... I'm desperate to sort it out, as its hacking off ownership of what is a great car.? Any suggestion please ?????? :sad:
Offline tinman
Re: 16v cutting out ????
« Reply #1 on: 06 December 2004, 19:40 »
had exactly the same thing.
it was either the injectors or the lift pump that eventually fixed it. its probably worth changing the fuel filter as well.
we weren't sure what it was on my valver but it cured it. plus i gained a lot of power. which was nice.
i dont think the parts cost that much. use the bosch injector and not the VAG part though. they are identical, but one costs a lot less.
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #2 on: 06 December 2004, 22:49 »
I have been told the merc injectors are better? anyway here is a how to sort of tut- http://www.steve-bratt.pwp.blueyonder.co.uk/tut/t.html
btw the injectors are ?34 each including VAT at the moment!
Offline tinman
« Reply #3 on: 06 December 2004, 23:16 »
superb page.
i used bosch rather than VAG as the fuel system on a 16v is made by bosch in the first place. not like you can wrong really.
Offline Gambit
« Reply #4 on: 07 December 2004, 08:47 »
id just get it setup correctly first off. what your describing is a common 16v problem
Stalling 16v's
Offline phil t
« Reply #5 on: 13 December 2004, 13:59 »
Gambit said,
 "Its a common problem. just need setting up correctly."
 Sorry for my ignorance, but what do you mean by that? Isn't? the whole engine/fuel management electronic and supposed to do that. If not how/where do I get it "set up correctly?"
Many thanks for the advice so far folks.
Veedubgt18v
« Reply #6 on: 13 December 2004, 22:27 »
the 16v is mechanical fuel injection, it doesnt have an ecu. the base settings like idle timing co2 etc need to be right for it to work properly.
Offline Gambit
« Reply #7 on: 14 December 2004, 09:17 »
replied to your PM
a 16v does have an ECU :wink: but it only concerns advancing the ignition timing
Veedubgt18v
« Reply #8 on: 14 December 2004, 09:18 »
yeah i know but its a common misconception
Offline 1369Phil
« Reply #9 on: 22 December 2004, 18:09 »
Mine does the stalling thing - only when it's been sitting in traffic for a while - and then it'll stall every time I slow down - I counted thirty times in a half mile journey home - not fun.
Could someone hazard a guess at the issue here - my car's done a good 100k miles - sadly it doesnt get opened up that often, lots of short journeys.
