Author Topic: Wazzzer's 1.8T... Lots of updates  (Read 403269 times)
Offline Chris.
Re: Wazzzer's 1.8T... ported manifold is here
« Reply #480 on: 09 March 2013, 19:46 »
Looking good mate!
Click For Build Thread
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #481 on: 09 March 2013, 19:56 »
Cheers mate
Powdercoated Audi TT bearing housings sourced, will be getting hub and ABS ring off a breaker next weekend and I'll order some new bearings, ABS sensors and splash guards as soon as I get paid so I can build everything up off the car
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #482 on: 13 March 2013, 21:58 »
These arrived, just over a tons worth of poly bushes :sick:
Also decided to get shot of the 3" exhaust, it's just too loud for the family. A replacement has been sourced, just waiting for delivery. This also means a 4mo rear valance will be making a return instead of the diesel Anni.
In case anyone is wondering, I've been doing a LOT of overtime lately so it's only right I should spend the extra :laugh:
Offline dom
  • Back in a Mk4
Re: Wazzzer's 1.8T... a few changes to make
« Reply #483 on: 13 March 2013, 22:53 »
Whats the new system?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #484 on: 14 March 2013, 06:55 »
Not sure mate, it's 2.5" all the way through Inc sports cat so should be a lot quirter
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #485 on: 19 March 2013, 22:46 »
Decided to crack on with splitting the spare hubs at work today, got this one completely stripped down ready for the TT bits to arrive
Drilled and tapped the brake disc retaining screw out too as my current hubs have the remnants of screws in them
Will have the other one done tomorrow ready for the bearings to arrive
VeeDubGTI16v
Re: Wazzzer's 1.8T... hub stripping
« Reply #486 on: 20 March 2013, 09:29 »
I thought the quicker racks played havoc with the traction control? Is there a way round it? (bar turning it off!)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #487 on: 20 March 2013, 09:56 »
Yes they do, it's to do with the angle sensor not reading right but I've got an AGU with no steering aid bar the PAS so I'll be ok :afro:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #488 on: 04 April 2013, 18:27 »
Looks like the Golf has finally bitten me in the arse after a lot of relatively trouble free motoring.
I decided to change the exhaust and cat over myself a few days before we were due to drive down to Weymouth for a holiday after my mate ramps were busy for the foreseeable future due to stripping his dad's Cortina down. This is where my nightmare began.
The exhaust came off fairly easy so I turned my attention to the decat and the nuts holding it to the turbo. Within 10 mins this was the progress or lack of
So I was stuck between a rock and a hard place. I decided to pull the turbo out and take it to work to get the studs out. After a bit of oxyacetalene treatment all the studs were out
I ordered new gaskets and studs and booked the day off work to get it done. It was all complete the day before we were due to go so all was well. It was also a chance to fit my modified manifold.
On the way I could hear a horrible "chattering" noise when the turbo was working so I had to do the whole trip off boost. Not very entertaining but great for fuel economy.
My only explanation for this noise is the oil feed to the turbo being restricted somehow. Unfortunately due to being on holiday I can't check anything so I'll have to wait until I get home at the weekend. I'm hoping the turbo isn't badly damaged but we'll see.
While the exhaust was off I thought it would be good to fit my B&M copy short shift kit. Relatively easy, and gives some good results. Just need to replace the heavy stainless knob with something a bit more pleasing to the eye and a bit warmer lol
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #489 on: 04 April 2013, 18:28 »
I've got my eye on a Richbrook leather/aluminium replacement with shift pattern. Bit restricted on styles as reverse is now lift up rather than push down but it should look OEM enough
In lighter news new ABS sensors and wheel bearings are on their way so I can build my TT hubs up ready.
More news after the weekend but I suspect I won't be good...
« Last Edit: 19 April 2013, 14:12 by Wazzzer »
