Author Topic: Wazzzer's 1.8T... Lots of updates  (Read 403780 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wazzzer's 1.8T... back to OEM
« Reply #100 on: 25 January 2011, 20:01 »
spent an hour or so up the hospital with my oldest this morning as she's got a chest infection so gonna spend the day with her today instead.
 :smiley:
Offline richw911
« Reply #101 on: 25 January 2011, 20:03 »
How much for the wheel if you dont mind me asking bud?  :smiley:
Offline Rhyso
« Reply #102 on: 25 January 2011, 20:03 »
 :smiley:
Meh - it takes 5 minutes to fit  :tongue:  You got a torch haven't you?  :laugh: :laugh:  Fit it when the little ones are asleep  :grin: :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #103 on: 25 January 2011, 20:04 »
£160 from Jordy  :smiley:
Rhys, Carrie would have my balls on a plate if I went out there now :grin:
Offline richw911
« Reply #104 on: 25 January 2011, 20:06 »
 :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin:
Offline Rhyso
« Reply #105 on: 25 January 2011, 20:06 »
Not as if you're going to need them again now is it  :lipsrsealed: :grin: :grin: :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #106 on: 25 January 2011, 20:10 »
very true, would save hassle at a later date  :cry: :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #107 on: 26 January 2011, 21:20 »
Catch can, standard airbox and piping all in and finished
and with the engine cover back on for a standard look...
Just need to trim a bit more off the side of the cover so the pipes aren't snagging but it's not too bad as it is
also found 5 mins to fit this
comments welcome :smiley:
Offline Toby
  • Car - less
« Reply #108 on: 26 January 2011, 21:26 »
looks like a good job jobbed :) :cool:
Currently down under
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #109 on: 09 February 2011, 21:59 »
Went over to JKM for a RR day at the weekend and it didn't go exactly to plan...
The Golf is running too much boost and was seen to hit 30psi on the rollers before the run was aborted. It was detting it's t!ts off apparently...
This is down to the N75 map on my car not being right for the Forge actuator that I have fitted recently. Nick tweaked it for my bent actuator last time I was up at R-Tech so I could have at least a bit of boost. In hindsight I shouldn't have even attempted to run it on there but you live and learn
So away I went licking my wounds but they had given me my money back so not all bad. After all that's what rolling roads are for...
So all in I let the mk4 fraternity down (I was the only one there) but I did however manage to get 168bhp and 260lb/ft at 3300rpm, the torque obviously showing the boost spike
A quick vid of the aborted run, note the black smoke when the fuelling was all over the place :sad:
To console myself I have decided to throw myself at the wheels again and get them done ASAP so I've been up in the loft at work in my breaks getting as far as I can each day
Before I went off on paternity leave I managed to get them etch primed so it was a quick rub down and a few coats of high build
a quick dust of colour
and a few more coats of colour later
will rub down the paint on there tomorrow and get a final top coat on, then lacquer. Then the tedious job of masking it all up to get the black parts done. Then just a quick balance and they can finally go on!
As usual, comments are welcome :smiley:
« Last Edit: 09 February 2011, 22:06 by Wazzzer »
