Author Topic: slow start and poor clutch in a mk4 tdi 115  (Read 3861 times)
Offline jweb
« on: 01 May 2010, 17:52 »
This has proberly been covered loads of times somewhere on this site but gonna ask anyway, ive got a mk4 tdi 115
1. its a bit reluctant to start first thing,turns over fine just struggles the fire up after that is spot on.
2. when the clutch is pressed down it clicks and sometimes will do the same on the way up or just when driving along,also when i push it down first thing it is really stiff to get in gear like the clutch isnt pushed down atall it becomes easier as the car warms up.
Offline alex160
Re: slow start and poor clutch in a mk4 tdi 115
« Reply #1 on: 01 May 2010, 22:27 »
Any fault codes present? Have you tried changing the glow plugs or the glowplug relay? With the gearbox i would try getting the oil changed to start off with.
2001 Golf GT TDi  150bhp/ 250 ftIb torque  *No smoke, No poke*
Jamex coilovers, 8k HID's, 18" RS6 alloys, Pipercross panel filter. Stage 1 Revo remap.THS FR3 engine mounts, Anniversary headlamps. GTI rear spoiler, Miltek largebore decat/downpipe, Pro-speed cat back exhaust system (V6 4mo style tailpipes) *SOLD*
2002 Golf GT TDi 130. Allard egr removal kit, 18" Audi rs6 alloy wheels. Mk5 rear aero wiper.gen R32 roof spoiler, JOM coilovers, JOM heavy duty adj droplinks
Offline jweb
« Reply #2 on: 02 May 2010, 10:28 »
no fault code present, took car out this morning even harder to get in gear mainly 1st,2nd and reverse.
will try oil change 1st then thanks.
Offline EuanGtTdi
« Reply #3 on: 02 May 2010, 13:13 »
I also found over the winter my car struggled to start but i had recently changed the glow plugs and it turned over fine i chnaged the battery and olla was perfect, if your glow plug sign stays on for a while its obvious them.
Offline jweb
« Reply #4 on: 02 May 2010, 15:02 »
right a set of plugs and oil is now on order and will be fitted a.s.a.p. will let you know how i get on.
Offline alex160
« Reply #5 on: 02 May 2010, 23:16 »
Just had a thourght on the gearbox issue mate, my brother which owns a bora 115 tdi had the exact same prob untill one day he cudnt select any gears :(, on inspection part of the gearlinkage had fallen apart, bascially 2 riviots had come loose and snapped off, they were re-rivioted and all was good. Give all the gearlinkage a good look over mate.
Offline jweb
« Reply #6 on: 03 May 2010, 11:20 »
nice one will have a look at it later thanks.
Offline jweb
« Reply #7 on: 03 May 2010, 12:45 »
been and had a look all seems sound so thinking its the clutch, does anybody know a good garage near twickenham that wont rip me off!!
have now changed bushes on the clutch pedal seems to have cured it for now will change gearbox oil to, car needs a service anyway.
« Last Edit: 14 May 2010, 17:30 by jweb »
