Author Topic: Help needed earth point  (Read 4194 times)
Offline ian007miles
« on: 29 April 2010, 19:17 »
Hi I need some help I'm movining my amps from behind the back seats to on the flore of the boot in front of my sub box, right against the back of the car and I was wondering were the best place was to earth them and I don't want the wire to be more than 12". The amps are kenwood kac-ps1d and a kenwod kac-ps4d and the car is a mk4 golf Gti . Thanx ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline troublestarter
Re: Help needed earth point
« Reply #1 on: 29 April 2010, 20:37 »
use an existing seat belt point as that is a good solid earth
just make sure you rub it back to bare metal for a good contact
you will need to use a large ring terminal as the bolt has a 10mm thread
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline ian007miles
« Reply #2 on: 29 April 2010, 20:47 »
I'M putting the amps at the other end of the boot back light end so no were near the seat belts mate
Offline wakeboarder15
« Reply #3 on: 29 April 2010, 20:59 »
the floor of the boot is a good point  :wink:
sand down the paint so its bare metal
dril into the floor (make sure there isnt anything underneath first!)
then put in your self taper :tongue:
did mine the other day...works a treat :cool:
« Reply #4 on: 29 April 2010, 21:50 »
don't just drill a hole and put a self tapper in it will eventually work loose
if you look behind the carpet trim on either side of the boot there are bolts with a nut on use one of them
if you do decide to drill a hole do so but use a captive nut in the floor
you would need a captive nut tool but this effectively rivets a thread into the boot floor and you can then bolt your earth point to that
Offline jonnypolish
  • t2871r needed :)
« Reply #5 on: 30 April 2010, 18:35 »
I have a Mk3 but similar set ups in all cars, i use a bolt off the rear light which is attached to the frame of the car,
I have a small adapter that the earth wire slides into, then the bolt tightens on top of it to make a solid connection
Could give that a try if you don't want to drill holes and the like :)
 MK2 VR y0!
Offline ian007miles
« Reply #6 on: 30 April 2010, 21:53 »
I want the best place to earth the amps cos once there in I ante takin them out so it's got to be right first time. Has any one got any pics of a good earth point
