Author Topic: Electric windows go down but not up!  (Read 1982 times)
Offline VR6_Wherry
« on: 21 April 2010, 14:50 »
Right guys bit of an issue here!
I'm trying to install my alarm when i must have connected some wrong wires...i heard a little pop and sure enough i blew a fuse. Looked through the fusebox an found it was number 20. This did the inside electrics, replaced and now is all good.
BUT now with the buttons i can only get the windows to go down and not up! if i leave the key in the door they go up and down...so i know it's not the regulators have i blown a relay?
Help please!!!  :sad:
kells
Re: Electric windows go down but not up!
« Reply #1 on: 21 April 2010, 17:10 »
sounds like a earth problem
Offline VR6_Wherry
« Reply #2 on: 11 November 2011, 15:08 »
I'm bumping this back up as i still haven't fixed this issue after a year and 7 months! been real lazy!!  :grin: :grin:
Offline tweed
« Reply #3 on: 11 November 2011, 15:32 »
I take it both door switches don't go up? must be a relay
Offline VR6_Wherry
« Reply #4 on: 11 November 2011, 15:39 »
Nope, they only go down. If i press up it stops them going down (normal)
I thought relay but can't find anything about them?
Offline tweed
« Reply #5 on: 11 November 2011, 15:45 »
to be honest i aint got a clue  :lipsrsealed: :laugh:
Offline trog_nfs
« Reply #6 on: 11 November 2011, 15:48 »
Sounds like you melted a wire somewhere to be honest.  :huh:
Offline VR6_Wherry
« Reply #7 on: 11 November 2011, 15:55 »
 :sad:
I'm looking around and can't find a fcuking thing!  :grin:
Looks like soldering iron will be out tomorrow and i will be pulling everything out! :grin:
I guess when i press the button to just see which one is clicking? Or is that the motor that clicks?
Offline Bellend
« Reply #8 on: 11 November 2011, 17:56 »
No relays all done internal to the motor electrics.
You cut through a wire somewhere?
Taken the connections off and back on?
Where all my moneys went.
Offline dan-swire1908
« Reply #9 on: 11 November 2011, 18:13 »
Had this problem in mine about three weeks ago.. turned out to be the pins in the drivers door switch were loose in the multiplug and not making a good enough connection to the switch. Try and get yourself some form of power probe and attempt to operate the windows using that. Failing that a short piece of wire to complete the circuits should sufice.
