The garage
Alternator 65amp or 90amp?
Topic: Alternator 65amp or 90amp? (Read 1505 times)
ASH
Here all the time
its a way of life!
25 November 2004, 17:34 »
gonna have to change my alternator, shuold it be 65 or 90 amps?
i know the GTi 16 valves normaly use a 65 amp, but as mine has the climate pack with A/C do i need the 90 amp?
cheers
mk1
2ltr16v turbo (now with programmable EFI)
Re: Alternator 65amp or 90amp?
25 November 2004, 23:18 »
Both will work ok, go for the bigger if you have it.
Steve.
http://www.geocities.com/mk1turbo16v/golf_turbo.html
1300mk2
26 November 2004, 08:27 »
would you have to uprate the wiring from the alternator if you went for a higher ammperage?
mk1
26 November 2004, 19:44 »
Hmm, good question. If the wires and connections are in good knick, you should be ok.
Steve.
The garage
