Author Topic: fitting door speakers  (Read 5146 times)
Offline ash159
« on: 19 April 2010, 20:04 »
A few questions. ive got a 1999 mk4 5 door and replacing all 4 door speakers, do these adapters have the plug at the top the same as the oem ones do?
http://www.caraudiodirect.co.uk/vw-seat-speaker-adaptors.html
so i can use with these http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400112457818
(Item number: 400112457818 )
and with the rivits on the oem rings do you just drill through them and then it comes away?
have the door card off atm so any replys within the next hour or so welcome lol
Ash
Offline troublestarter
Re: fitting door speakers
« Reply #1 on: 19 April 2010, 20:39 »
they don't have the plug on the top but a recess for the speaker cable to pass through they should also come with the speaker cable adapter plug so no chopping of wires
as for the rivets yes just drill them out and then screw the new ones on through the original holes but using a screw clasp  behind the metal work9these should also come with the speaker adapters
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline Devilz
  • Cruisin is not a crime
« Reply #2 on: 26 April 2010, 18:04 »
is it must to remove door cards or speakers can be removed from doors by removing grills and unscrewing?
« Reply #3 on: 26 April 2010, 22:36 »
doorcards have to come off
Offline Devilz
« Reply #4 on: 26 April 2010, 22:37 »
how to remove rivets then?
« Reply #5 on: 27 April 2010, 13:02 »
drill them out
Offline Devilz
« Reply #6 on: 27 April 2010, 14:51 »
Can I use same revits with new speakers or they need replacing as well?
« Reply #7 on: 27 April 2010, 15:11 »
you will need to either fit new rivets or screws through the existing holes with a metal clasp behind them to hold them in place
Offline Devilz
« Reply #8 on: 27 April 2010, 20:34 »
it sounds complicated, I guess I should get them professionally fitted
Offline Rhyso
« Reply #9 on: 27 April 2010, 20:56 »
NOOO!!! It's a 2 hour job max! Hour each side
As long as you buy the speaker adaptors you'll get everything you need to fit your new speakers
