Author Topic: air intake, too much? ...  (Read 1260 times)
Offline BADBOYDRUMMER
  • HI!
« on: 14 April 2010, 19:55 »
hi,just finishing a few jobs to get the aum up to scratch! i have fund a few split air pipes, causing a major miss fire and engine light to come on, could or would anyone be able to tell me where i can get a set from or if they know that there is a few exact ones that corrode, i was expecting some dodgy pipes as the car is on 112k and they are all original excpt for a brand new one, which is tiny but main dealer only and cost £35. are all the pipes main dealer only? has someone got a set i could buy? should i finda scrappy and take them from there? whats the best move? cheers guys!
Offline T_J_G
Re: air intake, too much? ...
« Reply #1 on: 14 April 2010, 20:18 »
Best to get new as they'll only split again. Dealer only :( what ones were split?
  • HI!
« Reply #2 on: 14 April 2010, 20:25 »
there were a few to be honest, the one i replaced forked slightly and the original had loads of caked oil inide it, that one was split and also the one it connets to vertically underneath it, the plastic connector snapped, and i think there was another one further back towards the turbo.
Offline T_J_G
« Reply #3 on: 14 April 2010, 20:29 »
You could always replace and bypass all that rubbish like i have with a catch can. Total about £80 which is a lot cheaper than all the hoses.
  • HI!
« Reply #4 on: 14 April 2010, 20:33 »
so i could remove that sh!te then!!! how easy or hard is it to setup??
Offline T_J_G
« Reply #5 on: 14 April 2010, 20:36 »
Very easy. You need some 19mm oil resiliant pipe and a 19mm t piece and a catch can. See my project thread for pics of mine!
  • HI!
« Reply #6 on: 14 April 2010, 20:38 »
thats cool, so by bypassing them will it cure my annoying misfire?
Offline T_J_G
« Reply #7 on: 14 April 2010, 20:39 »
It will if the holes are causing it.
  • HI!
« Reply #8 on: 14 April 2010, 20:42 »
i does look easy and it looks good aswell, fair do's! thank you very much!! you have been very helpfull!! cheers mate!
Offline T_J_G
« Reply #9 on: 14 April 2010, 20:46 »
The can is made by saiko mitchi and can be had for £60 if you buy in a group of 3.
http://www.saikoumichi.com/
« Last Edit: 14 April 2010, 20:53 by T_J_G »
