Author Topic: hate this car ...sump plug stuck  (Read 3499 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 11 April 2010, 15:05 »
Hi, my sump plug is stuck!  I have just had some serious force on it with a hell of a lever bar, and it just will NOT shift!!  Its starting to round off now!  :sad: :sad: :sad: :sad:
Any one had this problem before? I cant get my manky oil out  :angry:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline christomk3gti
Re: hate this car ...sump plug stuck
« Reply #1 on: 11 April 2010, 15:08 »
I wonder if its been cross threaded when the oil was changed the last time. Try a good set of stillsons on it and see if that grips it and undoes it. If not then you may have to get it drilled out.
Black 8v GTI............. Whats a Waffle Valve?
« Reply #2 on: 11 April 2010, 15:11 »
Weld a bigger nut on it, if it is crossthreaded then you going to need to sort the threads.
Offline tweed
« Reply #3 on: 11 April 2010, 16:04 »
mine was a right thingy!!!
I'm glad I've been weight trying for last 2/3 years. lol I had two foot bar and got on my back to pressed it up. It took as much force to bench 120kg!  :laugh:
Offline justalex81
« Reply #4 on: 11 April 2010, 17:45 »
i drove mine to kwik fit and had it up on the ramp. got a mahoosive torque wrench on and it finally came off.
Offline Matty-MK3
  • Automatic boats FTW.
« Reply #5 on: 11 April 2010, 19:09 »
^ Shouldn't undo things with a torque wrench.
You can try Irwin/Snap-On nut extractors, they work well but you need to hammer them on and obviously you can't go mad on a sump!
I'd try and to as Wayne suggested and weld on a bigger nut. :)
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline justalex81
« Reply #6 on: 11 April 2010, 19:49 »
i don't care it wasn't my torque wrench  :grin: :grin: :grin:
Offline Rmachines
« Reply #7 on: 11 April 2010, 20:59 »
Ah ok i had a 4ft breaker bar on it  :grin:
I have a set of snapon extractors at work, i will try my impact gun first, of not, sump off jobby!
Offline gazpowells
« Reply #8 on: 11 April 2010, 22:26 »
i had the same problem mate about 6months ago sump nut would just not let go  :angry:
i heated the nut up until red hot with map gas (which took a long time)  then hammered a 14mm socket over it, waited until it cooled then a nice long bar and it came out easy  :smiley:
Offline bmw156
« Reply #9 on: 12 April 2010, 19:05 »
REALLY.
i have never ever had a tight sump plug. if its ever tight, its usually im trying to undo it the wrong way...
